Question about Refrigerators
Subzero model 650 needs the condensor cleaned
We cannot find the detailed directions on detailed instructions on how to go about vacuuming the condensor area which is on top of the refrigerator
Model 650 refrigerator freezer combo
  • 90 Answers
The best way to clean the condensor coils on this model is to blow it out with an air tank.
Posted on Jan 08, 2008
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
How to vacuum condensor on Sub-Zero Model 650 ?
remove upper grill condensor will be on right take vacuum us the furniture attachment and clean if you are getting an vacuum cond. light on display you will need to call a servicer my number if you are in the dallas metro area is 8178515057 if not you can find a local servicer by going to factory web site subzero .com
Apr 18, 2012 | Refrigerators
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
Code vacuum condensor
clean your condenser coils. located in the top part of the fridge. unplug the unit before service. vaccum the condenser. if after 2 or 3 weeks the vaccum condenser comeback is really posible that you have an evaporator freon leak. in the fridge side
Mar 29, 2010 | Sub-Zero Bottom Freezer Refrigerator
Can't get temp in fridge to go below 50 F. Freezer works fine and makes ice. It started when our area had a heat wave and the inside of our house was 85+ most of the day. The ice maker stopped working,...
Have you checked the evaporator fan(freezer fan), This problem is hard to detect because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator.
Aug 01, 2009 | Refrigerators
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Sub zero 690
Call the factory at 800-222-7820.They will give you a list of the authorized servicers in your area. It sounds like the evaporator and the parts will be covered by the year 6 through 12 parts only warranty. If you are in Westchester County $625 sounds right. The vacuum condensor flashes when the compressor has too long of a run time and will reaapear a day or so after it has been reset. I assume the tech made sure the condensor fan was running and the condensr is actually clean.
Nov 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Vacuum condensor
open both the freezer and refrigerator doors, there are 4 screws at the top of the door frame that extend into the grill covering above the doors where the condenser is housed.  Remove all 4 screws, pull the grill open and then use your home vacuum to clean the dust from the condenser coil (it'll be obvious that it needs it).  Close the grill back, replace the screws and the message should go away.
Sep 08, 2008 | Sub-Zero 642
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
