Question about KitchenAid KGCC766RSS Stainless Steel Gas Cooktop
In this model of gas cooktop is the gas regulator inside the cooktop or outside? I got a open box deal without the gas reg. and wonder if it is inside or if I have to order one?
  • KitchenAid Master
  • 43,501 Answers
On most cooktops the regulator is installed externally and is not includes... if it is there it will be right on the pipe that you hook the gas too...
heatman101
Posted on Aug 30, 2010
GE Monogram cooktop ZGU385NSMSS (natural gas) without pressure regulator?
I have the same question, so any help would be appreciated. Mine came from a "scratch and dent" store without the regulator.
Oct 28, 2011 | Cooktops
Flame size will not regulate. Authorized Jenn-Air repairman came out and replaced the regulator and I still have inconsistent flame size on all four burners. About 1/2 the time it's like it's...
What other appliances work on gas? The furnace? The water heater? A gas dryer? How much propane is in the tank? I wonder how the cooktop would work on a seperate tank? If it worked perfect on another tank I would say you have a plumbing problem.
Oct 26, 2011 | Jenn-Air JGC8536 Gas Cooktop
I just bought this cooktop from Best Buy Auction. I cannot find the gas intake. There is just an opening there. Am I amissing some parts. Or how can I open the gas to find id the parts are inside the base...
Sorry to read about your problem, I hope this helps you out.
yes you are missing the gas regulator
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 14, 2010 | LG LCG3091ST 30 in Portable Gas Cooktop
Missing manual and gas diffuser
May I get the make and model # to help you get the manual.
Also from the gas supply from house to cooktop it should go like this.
gas valve
gas line
regulator
then cooktop
May 31, 2010 | Maytag MGC5430BDS Gas Cooktop
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
The high flame doesn't seem to be working on any burners
hi gud day...try to remove the nozzle inside the burner base using open wrench(depend the size)the use vacium,put the vacium were the place of the nozzle,i think there some dirt inside..then return it again the nozzle to check if it works,,if not replace the regulator for the 2nd sollution.
tnx gerbee
Sep 11, 2009 | GE Profile JGP636 Gas Cooktop
Where is the natral gas regulator located on the smeg cooktop
Hi, you should be able to see it. Get me a mosel # and I can look this up and give you exact location.
Vic
May 17, 2009 | Smeg 24 in. SER60S Gas Cooktop
New lp gas reg needed
hello Michael - I recommend that you call your propane provider. They will be able to help you.
please rate my answer. thanks
Jan 22, 2009 | Dacor Preference SGM365SS Gas Cooktop
Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
While he is there he can adjust the regulator to get it all working correctly
Mar 13, 2017 | GE 36 in.JGP970 Gas Cooktop
KitchenAid KGCC766RSS Stainless Steel Gas Cooktop Logo
170 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
