Question about NorStar M7324 Telephone
MERIDIAN M7324 my phone wont ring whith incoming calls
  • tor8 Sep 12, 2008
    I have the same problem... how do get into the system programming or into the trunk access lines. I have tried the **266344 but I do not see the access conditions.
Do you know how to program the system?
You will need to log into system programming. Got to lines/trunks and enter your extension. You will see the line appearances to appear only. You need to change those to appear and ring.
If you do not know how to get into programming. Call a professional.
Posted on Jan 08, 2008
    Problem Solver:
I cannot get my second phone to ring. it flashes and works normally,but will not ring.
The phone on the answer machine works fine.
Posted on Dec 21, 2008
6ya staff
SOURCE:
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
We have a Norstar - Meridian M7310 phone system. Today for some unknown reason when an incoming call comes in, the ring is two short rings rather that the "longer" ring that we normally have. I have...
The two short rings is telling you that the call is either a transfered call (answered by someone else and transfered) or answered by an auto attendant and transfered. Watch the ringing phone when the call comes in and see if the intercom LED blinks.
Bill C. www.dyna-tech.us
Mar 12, 2010 | NorStar M7310 Corded Phone
Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Jan 12, 2010 | NorStar M7100 Corded Phone
Old reception phone now regular office - reprogram
The display should say line 001: appear& ring
The display should say line 002: appear &ring
Oct 26, 2009 | NorStar M7324 Telephone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
My phone, a meridian M7208, does not ring incoming calls
following a power failure, the only phone that rings is the one in reception. light still flashes but no ringing from any other phones
Feb 16, 2009 | Nortel Meridian M7208 Corded Phone
Meridian m7324 - another phone in office - DND - unable to remove
You almost had it right . You need to do this press the feature button then # 85 to remove the DND .
Feb 02, 2009 | NorStar M7324 Telephone
Merian M7324 display name
you would need to get into the admin programming to change the name, have your system admin person make the change for you.
Jan 02, 2009 | NorStar Meridian M7310 Phone
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
NorStar M7324 Telephone Logo
681 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
