Question about Uniden TRU9480 Cordless Telephone
My new hand set will not detect my base - Uniden TRU9480 Cordless Telephone
  • 3 Answers
Same manual as lethean but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Posted on Nov 01, 2008
    Problem Solver:
  • 12 Answers
Have you followed the instructions for handset registration? For some of the newer handsets, you may need to refer to the instructions that came with the handset (and not the base) instead of just putting the additional handset in the base to register it.
Page 23 of the 9480 manual gives explicit registration instructions.
Posted on Jan 09, 2008
Hi i have a uniden ZO68 i want to add another hand set to this i have brought another uniden ZO68 second hand hand set and i can't set it up can you help me please
did you get the charging base with the hand set
is it a charging base or a base station base
if it is just a charging base , follow the instructions as how to get the base station to recognize the next phone
if it is a base station, probably won't work as you will have 2 base stations trying to work and that will create conflicts
talk with a telephone technician to see what can be done
Oct 30, 2016 | Uniden Lands Phones
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
the base cradle, etc.
The manual is available from: www.manualslib.com
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
The in use/charge indictor light does'nt come on when i put phone on it. I just brought a new battery.
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Chris
Sep 03, 2011 | Uniden Cordless Phone
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
Phone will not register with base
Would you try this procedure:-
First on the base station..press and hold paging/register key for 3 seconds
Than on the hand unit select function key and open "MENU"
select "SETTING" from menu and confirm (Ok)
Selecect "HANDSET" and confirm
Than select" REGISTER" and confirm
than enter "0000" as pin and confirm..
it will flash and it detects the base.
Take care..
Nov 14, 2009 | Siemens Gigaset S440 Cordless Phone
I bought a new AT&T 2300 to go with my existing 2365 base and 3 2300 handsets. When I place the new 2300 in the base, after charging it, nothing happens no matter how long I leave the new 2300 in the...
possible that the new hand sets are not compatible with the base as it requires same hand sets as the base for the base to be able to register the handsets
follow the user manual to see if there is a how to register section that will help identify the problem
Jan 30, 2018 | AT&T Lands Phones
Sony SPP-A946 base unit intermittently charges the hand set.
Clean the contacts on the handset and base that charge the battery.
AL
Mar 17, 2009 | Sony SPP A946 Cordless Phone
Probelm with registering additional headset for the philpsse 7450
OK here it is leave the additional hand set base plugged in & take the hand set with you to the main phone & base. 1. unplug the main base.
2. with the main base unplugged hold the find handset button on the base.
3.with your finger still on the find hand set button plug the base back into the power.
4.charge light on main base should be flashing.
5.while the light is flashing press & hold the hash # button on the additional hand set only until it says registration complete & its all done.
May 02, 2008 | Lands Phones
No Link To Base Unit
I am having the same problem!
Mar 10, 2008 | Panasonic KX TC1743B Cordless Phone
Uniden TRU9480 Cordless Telephone Logo
538 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
