Question about Canon PowerShot S500 IXUS 500 Digital Camera
Screen is out of focus with a ragged white bit at
Screen is out of focus with a ragged whitish area at top when try to take a picture
on playback colours are wrong (pink sky etc)
welcomejee
  • 10594 Answers
SOURCE: I'm noticing all my pictures have a pink hue to it, and pink bar on top
Hello,,,
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck....
Posted on Nov 06, 2008
zohail
  • 1223 Answers
SOURCE: pink tint in pictures taken using canon s500
CCD FAILURE !
Call Canon for FREE REPAIRS it is a known issue ask them about BAD CCD see this link for service advisory
RATE ME WELL !
Regards
Zohail
Posted on Jun 01, 2009
  • 11967 Answers
SOURCE: Pink pictures
Check what setting the white balance is on. Also, go into the setup menu and do a reset of the camera.
Posted on Aug 25, 2009
  • 54 Answers
SOURCE: Colour balance for majority of photo is good but
How about White Balance? Taking a photo outdoors, for example, white your WB is set on "Fluorescent Light" will turn your images bluish. To set WB, see the owners manual.
Posted on Apr 16, 2010
  • 4090 Answers
SOURCE: Pictures taken recently have a pink tinge, eg the
your settings are wrong on the brightness and contrast
some of the power shots set up by using KELVINS as the method of balancing the warmth or coolness of a picture. Others have a setting for OUTSIDE Inside Halogen and fluro If its set on halogen and you are taking pics outside it will have a red tinge.
Fluro a blue tinge...
check the manual for the right selections
please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
I cant view the picture clearly while shooting and playback too.i was on a picnic 2wks back,and was taking pictures with my canon SD550 POWERSHOT CAMERA.. all of a sudden the display in the screen blurred...
There is a focuing ring with electromagnets on it, and it swivels to focus. When sand, dirt, lint, or dust works its way into the lens assembly, it can get stuck, failing to focus.
Spray some compressed air into the lens area to try to dislodge it. Then bump it gently if the compressed air doesn't work. Here is a list of things you can try for a jammed lens:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If these don't work, your focus ring is jammed and you will have to fix it or have it serviced. Get an estimate first, since the cost of repair often justifies buying a new camera.
Good luck, these tips might help you.
Aug 27, 2010 | Canon Cameras
My color seems to be more green than should be and I have tried to reset the color with no help
You have a focus/screen control box Find it and adjust the R/G/B screen drives When you first start Go to Menu turn Color off then with a mirror adjust the picture as close as you can to a black and white picture R/G/B screen drives, the little control box you are looking for will have 3 controls on top for focus and 3 controls under them for screen drives to each tube red,green,blue after you have adjusted to a black and white picture then go back and turn color on.
Nov 30, 2009 | Akai PT4298HD Rear Projection Television
DSC L1 is not supporting 4GB memory stick???????????? Says memory card problem
    Please disregard the 'Busy' message which may appear on the LCD screen during MPEG movie recording in VX Fine mode. Recording and playback operations, as well as recorded data, will not be affected.
Sep 26, 2009 | Sony Cyber-Shot DSC-L1 Digital Camera
White lines on the left side of the screen
well, your camera's LCD has a dead row of pixles you cant fix that, you can try ignoring it, and if yo cant ignore it, then a specialist can probably replace the LCD
Jul 27, 2009 | Pentax Optio W30 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Problem with image
What mode is the camera in? is it in "Auto" at the top there is a dial switch it to auto and press button halfway (shutter button) when you press the button halfway the camera will beep and display a square box on the LCD. If the camera beeps once and the box is orange it could not focus and you need to retry pressing halfway again. When it is in focus it will beep 2 times and it will show a GREEN box. This is the indication it could focus on the subject correctly. Its a machine and sometimes it takes it a bit for it to figure out what your wanting it to do. Its the nature of the unit
Apr 03, 2006 | Canon PowerShot A85 Digital Camera
Canon PowerShot S500 IXUS 500 Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
