Question about RIM BlackBerry Pearl 8120 Cellular Phone
My address book is gone but the phone numbers thats I have received or dailed out are in my phone. When tring to save it states duplicate name. How do I get my old address book.
I have over 5000 of the same name in my yahoo contact list,unable to delete it or merge,there is no address,just name
Remove Duplicate Contacts from Yahoo! Mail
To remove duplicate contacts from the Yahoo! Mail address book:
  • Follow the Contacts link in Yahoo! Mail.
  • Select Tools ' Clean up Duplicates... from the toolbar.
  • Click a suspected duplicate.
  • Make sure all address book entries that do not belong to the one you're consolidating are not checked (for Merge this duplicate) under Duplicates.
  • Click Edit under Merge Preview to remove any extraneous data or make other desired changes to the newly merged contact.
  • Click Save and Next.
Using Merge all EXACT on the duplicates list, you can quickly eliminate any dupes that are precise copies without differences.
Jul 29, 2014 | Toshiba Computers & Internet
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
Cant type name into phonebook,it will only type numbers
No you can't lose all that you have in memory, but that is not the solution to your problem.try to dail the number you want to store or save on your phone then stop the dailing the number click on the number you dail again and go to option when you click on option it will bring some list for you click on save then type the name and save the number is there already.
Dec 20, 2011 | Panasonic KXTG7230EM Phone
Received call has been named by me - ie saved for future use but cannot find in address book - how do I add to address book from the received calls list
HI
go to receivd call list.
select number you want to save
click option and select save contact.
do further process.
thank you.
Sep 14, 2011 | Motorola Mobility RAZR V3
I saved two numbers in my phone, 9946677999 and 9846677999...now i cant see the callers name while receiving or dailing to this numbers...can u help me to fix it...my phone is nokia n95 and connection is...
You will have to fix a name to the save number that is in the contact list. so open the contact list and edit the numbers you have speciifed with the new names and save.
now the contact list should work.
Sep 24, 2010 | Nokia Cell Phones
I have a nokia n95-1. I have copied sim contacts to the phone which have duplicated when I synchronised with Outlook. I can cope with that. What I dont understand is why the numbers of any of my contacts...
When you receive a phone call, the phone will look up in it's address book to see if it can find a match for that number, if there is only one match, great, it will display it, if there is more than one match, it would be difficult for the phone to 'guess' at who is calling, so instead it just displays the number.
First make sure you do not have duplicate Entries for the same number.
I would suggest you to do the following:
  1. Make sure you have copied all the contacts from your SIM to Phone
  2. Delete all the Entries from your SIM by selecting them at once
  3. Make sure you do not have any Duplicate Entry in the phone book
  4. If you suspect having duplicate entries, Sync. the phone with Outlook and search for Duplicate entries to delete them
Please make sure you have selected the default memory as SIM and Phone. If you have stored your contacts in the Address book of your Phone memory and selected the Sim card memory as the default phone book it is obvious that when receiving a call your phone will try to look for that number in the default memory selected by you or vise-versa.
Go to phonebook > Settings > and select the memory in use as Phone and SIM
Hope it is not confusing
Please get back for any clarification
Thank you for using Fixya
Oct 08, 2009 | Nokia N95 Cellular Phone
Is there any way to make the persons name appear for a text
It should be as simple as adding their name and number to the address book on the phone.
Make sure to list the number under the Mobile Phone line.
While in the address book, there is usually a line that says "New Entry" or "Add number" etc...(without the type of phone I cant get specific).
Another method is to into the text message itself and do an options click (again without the phone cant be specific) and there should be an option to add the number to the address book.
Aug 05, 2009 | Cell Phones
Trouble with contacts
Was your Sim card copied to the address book?
You may have to fix the entries copied from the sim card into the address book so that the cell phone number is in the correct field as well as the names. By default it may not be properly stored into the correct fields.
Mar 18, 2009 | RIM BlackBerry 8700c Cellular Phone
Can't see addressbook name when i receive a text message
That means that there is a double entry. the number saved in your address book has eitehr been saved twice or saved twice with different names. Delete the entry in the address book then turn off and on your phone. you should see the name of the other entry now.
Jan 05, 2009 | LG Shine KE970 Cellular Phone
Texting
simlpy just because you have entered morethan one entry w/ that contact number..
Jan 11, 2008 | Nokia 1600 Cellular Phone
RIM BlackBerry Pearl 8120 Cellular Phone Logo
56 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
