Question about Zanussi 24 in. ZSF6120 Free-standing Dishwasher
I have a Zanussi Electrolux ZSF6126 and the
I have a Zanussi Electrolux ZSF6126 and the water is not heating up and it is not drying
  • Anonymous Mar 16, 2014
    why won't my dishwasher work zanussi zsf6126 red end light flashes three times
    Scholar:
  • 103 Answers
Check to see if the heat element in the bottom inside is all crusty or cracked, if so replace, if not, unplug unit from house current, pull bottom toe panel off, you should see where heat element comes thru cabinet and has two wires attached, remove wires, take ohm meter and check for reading, if reading is ok then you either have bad control timer circuit (main board) or blown thermal fuse. Call tech to check further if you do not have original tech sheet or electrical background. My bet is that you have a bad heat element.
Posted on Nov 12, 2009
Testimonial: "Great advice-I am not very confident electrically so looks like I need to get the bobs together and pay technican. Now I can tell him what problem is"
Electrolux Dishwasher EWD6505GS0B won't heat water?
Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately. Unit may have a faulty heating element a communication problem with the board not responding.
Oct 15, 2012 | Electrolux Dishwashers
I have Zanussi DX6453 dishwasher. Suddenly it is not drying our dishes. All programs working. Do you think is problem with Element or Thermostat. It is heating water.
sugget the water temperature, it relies on the temperature of the water to heat to items up so that when the wash cycle has finished the heat will dry them. Hope this is useful. Regards Mike
Jul 07, 2011 | Zanussi Dishwashers
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
Dishwasher not heating up
I found that resoldering the main PCB cured a dry joint and all is hot again
Apr 06, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
Wont heat or dry
hi have you tried thermostat i repaired on last week same fault
Dec 20, 2007 | Zanussi 24 in. DE6850 Free-standing...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Water isn't heating up and not drying
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
Mar 12, 2007 | Zanussi 18 in. ZSF4123 Slim-Line...
Zanussi 24 in. ZSF6120 Free-standing Dishwasher Logo
769 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
