Question about Leviton Decora Illumatech Slide Dimmer with Preset LED 600Watt White and Al
How many t8 fixtures can be wired to one Illuma dimmer #IP710-DLX?
  • 89 Answers
T8 lamps not familiar .
but here is a formula the switch should have a rating on it either in watts or amps. you can only load any electric control or switch to 80% of its rating .
so if its rated 300 watts you can use 240 watts of lights so if a t8 is 40 watts you can control 6 t8's
if the switch is rated at 15 amps take your 40 watts divided by your supply voltage 110/220 .. so 40 watts divided by 110 .36 amps,
now remember you can only load to 80% 12 amps in this example you could control 33 40 watt lights
Posted on Nov 12, 2009
    Problem Solver:
  • 13 Answers
If there are 8 in number t8 then there can be 8 wired.
My minka wire light does not work is it the dimmer switch on the fixture
Check for 120Vac cming into the light fixture, if its there, the problem is your fixture, the fixture switch, or the way you wired it into the circuit.at the light fixture
Aug 17, 2014 | Minka -Aire Brushed Nickel Remote Control...
Leviton Trimatron push on/off dimmer 705
Dimmer: the green wire is for bonding (grounding or earthing) the metal face frame. Do not connect it to the black or red wires. There should be a bare or green wire coming into the box, or the box (if metal) should be grounded through a wire or metal conduit. If the box is metal and you find a bare wire connected to the box, disconnect that wire and replace it with a 6" + (i. e., long enough to extend 6" out of the box) bare wire pigtail. Connect the 6" wire and the green wire to the original bonding wire using a wire nut. The two black wires are electrically interchangeable; they connect the hot wire to the light fixture (in place of a switch).
Existing house wiring: this is a head scratcher. In US residential wiring, one might see a 3/1 non-metallic cable with a black, red and white wire plus a bare wire for bonding coming from a light fixture. This would be used in one of two ways. In one, the black would be hot, the red would be the switched wire to the light fixture, and the white would provide a neutral connection for lighting control devices that need it. In the other (possibly more applicable to your situation), the white would be marked with black tape and would serve either as the incoming hot or as the switched wire to the lighting fixture (the black would have the other function), and the red would serve as a second switched wire for a fan or other load. The wise thing to do would be to remove the lighting fixture and have a look at the other end of the cable - take special note of the connections going to the fixture(s). You are looking for the hot connection coming in to the fixture box and the switched wire going to the fixture. But two black wires? How is it possible to tell which one is which without turning on power? Is there a difference in insulation marking? Or are the connected together?
Another common configuration (and I think this is what you have) is to bring hot and neutral into the box from the branch wiring, then send the switched connection(s) out of the box, and tie the neutrals (white wires) together with a wire nut. (Look for the neutral connection inside the box; if you find one, the job is relatively simple) In this case, one of the black wires is the incoming hot (comes from the cable without the red wire but with the incoming neutral), the other black wire and the red wire go to the fixture in the other cable along with the outgoing white neutral wire. You still need to look at the fixture to find out whether it gets the black wire or the red wire. It is possible that one of the wires (most likely red) is a spare for possible use in a fan/light combination.
Once you have identified which wire is the incoming hot and the switched wire going to the fixture, connect one of the black wires on the dimmer to the hot and the other black wire from the dimmer to the switched wire. What you do with remaining wire depends on what is done with it at the fixture box. If it is an unconnected spare, tape over the end (if stripped) and push it back into the box so it doesn't accidentally poke into a wire not and become energized. If it is connected in parallel with one of the other wires (unlikely), do the same at the dimmer box end. If it is connected to another load (probably a fan), consider replacing the dimmer box with a double gang box and adding a separate switch for the fan (do not run the fan on the dimmer!).
If you have any doubt about what you find, you should hand this job over to a professional electrician. There are a couple of ways to get into trouble with this, especially if the person who originally wired the fixture didn't follow the electrical code. The worst case is you connect the two switched wires to the dimmer and leave the hot wire open and exposed inside the box, and it comes into contact with a metal part in the box. This is potentially dangerous and destructive.
Jun 22, 2013 | Cycling
How to change bulb thats a t8 fluresent fixture in a home
A Lot of the T8 style have very little room to move the tubes around, check a few things:
See if you need to remove the tubes in a specific order,
See if the ends of the fixture are removable,
Instead of dropping both ends of the tube drop one side first,
Sometimes after the tube has been twisted and dropped slightly you may have to maneuver the pins to avoid the fixture.
Dec 11, 2012 | Philips 6996C FKD 230V 1000W Lighting
Are 24 watt t5 lights brighter than 24watt t8 lights
brightness is only greater if the lums are higher, so no if you use the same wattage, remember t8 lamps will only work in t8 fixtures, same with t5 lights, only in a t5 fixture, there are brighter lamps for both fixture you just have to look as to how bright you want
Sep 15, 2011 | Home
Can I connect 2 lights to this dimmer and how do I wire it?
If you want two fixtures to be operated by the same dimmer, it is easier to just connect the fixtures together by twisting leads together and then wire nutting them and then run one set of leads to switch. That way you meet all codes.
Jun 12, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
3 way switch and dimmer. Switch and dimmer both turn light on and off. However dimmer does not dim the light. Dmmer had performed properly until replaced light (did not change dimmer or swith wiring only...
Please describe the old light fixture and the new light fixture. If the new light fixture is fluorescent, then using a dimmer with it won't work and is a fire hazard - unless you have a specially designed ballast which is designed to be used with a standard dimmer. If that is what you have, then the ballast in your new fixture is bad.
May 10, 2010 | Electrical Supplies
I'm installing a vanity light in the bathroom. The old one had a dimmer attached. For the new fixture, attached two white from the wall to the white in the fixture. attached two white from the wall to...
Get a test light, a bulb in a socket with a black and a white wire. disconnect both the black and the red. Also have access to the white or the ground. Then with the power hold the white test light wire to the white of the house and the black to the black. .turn the dimmer on and off and see if it controls the light. NEXT do the same with the red, that is test light black held to red and test light white held to house white. once again check the dimmer.
Typically when you have a hot red and a hot black in a fixture the black is on the dimmer and the red is always on because it is connected to an outlet built into the light. OR the light can be controlled from two locations, one regular switch and one dimmer switch.
Mar 01, 2010 | Electrical Supplies
Rotary dimmer control for 5 light chandelier stops dimming
Whoa...You definitely may have a fire and/or shock hazard hanging from your ceiling. I've seen a lot of fixtures with old, brittle wire and bad insulation in them. Lamp wiring is subjected to a lot of heat, especially with higher-wattage fixtures. Long term exposure to heat near or above the insulation's rating is especially damaging to electrical insulation. I've also seen cases where metal parts of the bulb socket partially melted and/or broke loose.
If you're comfortable and confident of your abilities to make a safe electrical connection, you can replace the wire and bulb sockets in your fixture. If it's valuable or an attractive antique, it's worth fixing or having fixed, even if you sell it. Just make sure you use wire with insulation rated for use in an electrical fixture. It must be rated for a temperature no less than 105 degrees Celsius.
It it's a lower cost fixture, replace it or have it replaced. Regardless of what you do, you're probably going to be replacing that dimmer again...sorry.
If you live in an older home, it may be worth (in terms of safety) having a few qualified electricians evaluate your electrical system as a whole to make sure everything is still in safe condition.
May 04, 2009 | Rotary Lot 10 Leviton Ivory Light Dimmer...
Trying to hook up a dimmer switch it has a red black yellow and green wire the box has a black white and ground which wires get connected together?
For a single-pole installation:
1. Connect the 2 white wires together (one from the source and the other to/from the light fixture) - 2 wires
2. Connect the black wire from the source to the black wire on the dimmer switch - 2 wires
3. Connect the black wire to/from the light fixture to the red wire on the dimmer switch - 2 wires
4. Connect the ground wires - 3 wires
Mar 23, 2009 | Electrical Supplies
Leviton Decora Illumatech Slide Dimmer with Preset LED 600Watt White and Al Logo
311 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
