Question about Canon Pixma MP480 All-In-One InkJet Printer
After selecting language and pressin OK message on LCD screen "set the ink cartridge". Cannot go any further than this message except switch off. Restarting brings back the language.
The solution was simple. The printer belonged to a friend who assured me he had replaced both ink cartridges when they ran out. So for some time I did not check them. On removing one cartridge it was obvious that he had accidentallyor unknowingly removed the contact strip on the print head so the printer could not detect or use the new cartridge. An expensive mistake for a newcomer to home printing as he had done the same to both cartridges.
Posted on Nov 13, 2009
How to change ink cartridge in epson nx215
1. Turn on your Epson printer. 2. If a cartridge is expended, you see a message on the printer's LCD display screen. The icon on the screen indicates which color to replace. Press ink.13.7.1.jpg Start (NX210 Series) or OK (NX410 Series). If you're replacing a cartridge before you see a message on the printer's LCD display screen, do one of the following: NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press ink.13.7.2.jpg or ink.13.7.3.jpg to select Ink Cartridge Replacement, then press ink.13.7.4.jpg Start. NX410 Series: Press Setup, press ink.13.7.5.jpg or ink.13.7.6.jpg to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 3. Open the scanner. Note:
Your printer model may vary from the ones shown in this section, but the procedures are the same. ink.13.7.7.jpg Note:
Do not touch the white cable inside your printer.
Do not open the ink cartridge cover while the print head is moving. ink.13.7.8.jpg 4. Open the cartridge cover. ink.13.7.9.jpg 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.13.7.10.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) ink.13.7.11.jpg 7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. ink.13.7.12.jpg 8. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. ink.13.7.13.jpg 9. Insert the new cartridge into the holder and push it down until it clicks into place. ink.13.7.14.jpg 10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. ink.13.7.15.jpg 11. Lower the scanner. ink.13.7.16.jpg 12. Press ink.13.7.17.jpg Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. If you continue to see an ink replacement message on the LCD display screen, Press ink.13.7.18.jpg Start (NX210 Series) or OK (NX410 Series) and press down all the cartridges securely. Then press ink.13.7.19.jpg Start (NX210 Series) or OK (NX410 Series) again. Note:
If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. Caution:
Never turn off your Epson printer while ink is charging or you'll waste ink.
(Taken from the Epson online manual available here)
Oct 16, 2012 | Epson Stylus Multifunction Inkjet Printer/...
How do i change my ink cartridges in my epson workforce 520 series 3 in 1 printer?
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Leave the expended cartridge installed until you have obtained a replacement, or the ink
remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If a cartridge is expended, you must replace it to be able to print or copy. If a
cartridge is low, you can continue printing until a cartridge needs
replacement.
If you're replacing a cartridge before you see a message on the LCD screen,
press xMenu, press u or d to select Maintenance, and press OK. Then
select Ink Cartridge Replacement and press OK.
3. Open the scanner, then open the cartridge cover.
4. Squeeze the tab on the cartridge and lift it up.
Warning:
reach of children and don't drink the ink.
5. Before you open the new cartridge package,
shake it gently four or five times. Then remove
it from the package.
6. Remove the yellow tape from the bottom of
the ink cartridge.
Caution:
leak. Do not touch the green chip on the front of
the cartridge. This can damage the ink cartridge.
7. Insert the new ink cartridge into the holder
8. Once you replace all the cartridges that need replacing, close the cartridge
9. Close the scanner.
10. Press OK to begin charging the ink. This takes
about 2 1/2 minutes. When you see a
completion message on the LCD screen, ink
Caution:
Never turn off the product while ink is charging or you'll waste ink. If you see an ink
replacement message on the LCD screen, press OK and press down all the cartridges
securely. Then press OK again. If you remove a low or expended ink cartridge, you
cannot reinstall and use the cartridge.
See Page 47 in manual
Download Manual Here
May 23, 2011 | Office Equipment & Supplies
Install ink cartridges for an Epson 315 workforce
If you do not want to go through the guide, here is a quick instruction on how to insert the ink cartridge.
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. If an ink cartridge is low or expended, you see a message on the WorkForce 310 Series LCD display screen indicating which color to replace. Press OK. If you're replacing a cartridge before you see a message on the WorkForce 310 Series LCD display screen, press the ink.9.7.1.jpg Copy button, press ink.9.7.2.jpg Menu, press ink.9.7.3.jpg or ink.9.7.4.jpg to select Maintenance, and press OK. Then select Ink Cartridge Replacement and press OK. 1. Open the scanner, then open the cartridge cover. ink.9.7.5.jpg 2. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.9.7.6.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 3. Before you open the new cartridge package, shake it four or five times. Then remove it from the package. ink.9.7.7.jpg Caution:
Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 4. Remove the yellow tape from the bottom of the ink cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 5. Insert the new ink cartridge into the holder and push it down until it clicks into place. 6. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place. ink.9.7.8.jpg 7. Close the scanner. 8. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Go through your user manual for further guide on how to install ink.
Jan 16, 2011 | Epson Office Equipment & Supplies
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
NX415 inkjet catridge refill
This is what I found on the Web. You can download the Manual if you like. Click on link below. Not able to put all here, do to limitation.
http://files.support.epson.com/htmldocs/nx415_/nx415_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones.Caution: not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1.
2.
If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press or OK (NX410 Series).
If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
to select Ink Cartridge Replacement, then press Start.
NX410 Series: Press Setup, press or to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
Apr 04, 2010 | Epson Stylus NX400 InkJet Printer
Sx415 I am unable to line up the printer head to
***hi there,il be willing to help you on that. ****
2. If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press Start (NX210 Series) or OK (NX410 Series).
***If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press or to select Ink Cartridge Replacement, then press Start.
3. Open the scanner. Do not open the ink cartridge cover while the print head is moving.
Caution:
12. Press Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
How do I change the ink cartridges
1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner.
Warning:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
got this from the Epson Site
Jul 29, 2009 | Epson Stylus CX4800 All-In-One InkJet...
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
CAUTION:
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
Ink
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
Canon Pixma MP480 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
