Question about HP Compaq Presario 2135US Notebook
How to replace the battery - HP Compaq Presario 2135US Notebook
  • 2102horn Nov 12, 2009
    the battery for power thanks.
  • joecoolvette
    joecoolvette May 11, 2010
    Which battery? The battery for power, or the CMOS battery? (Also referred to as RTC battery)
  • 33 Answers
Slide the battery's release latch, then pull the battery out of its compartment. Here is the link: http://h10032.www1.hp.com/ctg/Manual/c01122313.pdf - page 75. Hope that helps.
Posted on Nov 12, 2009
Testimonial: "quick and right to the point "
I am trying to figure out what battery the FP arctic cat green y6534-9665 ride on toy
12 volt.
12V Battery for Arctic Cat 650 L2170 Power Wheels Fisher Price
https://www.amazon.com/Battery-Arctic-L2170-Wheels-Fisher/dp/B01ACDHB56
Replacement For POWER WHEELS ARCTIC CAT 650 P8814 BATTERY. $109.93 ... $72.50. Replacement Battery for Fisher-Price Power Wheels 12-Volt Battery.
Amazon.com: Replacement For POWER WHEELS ARCTIC CAT 650 ...
https://www.amazon.com/Replacement...ARCTIC-BATTERY-Battery/dp/B01JGOAXS... Power Wheels 12-Volt Rechargeable Replacement Battery · 4.2 out of 5 stars ... $68.69 Prime. 12V Battery for Arctic Cat 650 P8814 Power Wheels Fisher Price.
Power Wheels L2170 Arctic Cat Replacement 12 Volt Battery Charger
https://www.amazon.com/Wheels-Arctic-Replacement-Battery-Charger/.../B01HIM3HX...
Buy Power Wheels L2170 Arctic Cat Replacement 12 Volt Battery Charger: Ride-On Toys - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Arctic Cat Batteries ' Replacement Battery for Arctic Cat ATVs
https://www.batterystuff.com/batteries/atv/arctic-cat/
Whether youre looking for a Arctic Cat or other ATV Batteries, youll find what you need at ... YTX14AHL-BS Scorpion 12v 210 CCA AGM ATV & Motorcycle Battery ... SSTX20HQ-FP Scorpion Stinger 12v 525 CCA LiFePo4 Quad Terminal ... Missing: green ‎y6534 ‎9665
Arctic Cat Batteries ' Replacement Battery for Arctic Cat Snowmobiles
https://www.batterystuff.com/batteries/snowmobile/arctic-cat/ Get replacement Arctic Cat batteries. Whether you%u2019re looking for a Arctic Cat or other Snowmobile Batteries, you%u2019ll find what you need at ... Missing: fp ‎green ‎y6534 ‎9665
Power Wheels Arctic Cat - Green ' CLG79 ' Fisher-Price
https://fisher-price.mattel.com/shop/en-us/fp/.../power-wheels-arctic-cat-green-clg79 Rating: 2.2 - ‎4 reviews - ‎US$309.99
Check out the Power Wheels Arctic Cat - Green (CLG79) at the official ... high speed lock-out; Power-Lock® Brake System; Includes 12-volt battery and charger.Missing: y6534 ‎9665
May 23, 2018 | The Toys
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
Change batteries
It is helpful if you identify the device, the brand, the model and sometimes the operating system when asking about a procedure or device. By process of elimination, I presume you are referring to removal of batteries from a tablet computer. Most if not all are not designed for simple battery replacement. The batteries may be connected to the hardware by solder. The batteries may be replaced but that requirement makes it clearly a task beyond simple swapping out of batteries. Here is a link:
How to Replace the Battery on Galaxy Tab 7 Inch
Upgrade Replace Your Chinese Tablet Battery
Replace lithium tablet battery 3 5 wires with 2 wire INSIGNIA NS P16AT08
How to replace tablet battery
Oct 14, 2017 | Computers & Internet
How do i replace built-in battery in apple iPhone5?
  • According to my information your one-year warranty for iPhone includes replacement coverage for a defective battery. First check it whether your iPhone is within warranty or not. If it is out of warranty, Apple offers a Battery replacement for iPhone, subject to local tax. For the products like built-in batteries, only Apple should replace the batteries or an Apple authorized service provider. Apple and its authorized service providers will ensure the spent battery is recycled properly, since batteries should always be recycled or disposed separately from household waste.
  • Thanks
Apr 25, 2014 | Apple iPhone Smartphone
When does the batteries need replacement?
the shaver will slow down as the batteries discharge. To suddenly stop suggests either loose batteries or faulty switch. There should be a charging cradle for the shaver to keep it working but if you need batteries then open the battery cover and replace with the same batteries.
Jun 26, 2013 | Health & Beauty
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Jun 01, 2008 | Casio DBC1501 Wrist Watch
Buy replacement Dell laptop batteries or oringinal ?
Usually you can save a good amount of money by replacing the battery with one made by a 3rd party. You can find a replacement for most laptop batteries at Batteries Plus.
Nov 14, 2007 | Samsung V20 XVC 2400 Notebook
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
HP Compaq Presario 2135US Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
