Question about U-Line Wine Captain (2015WC) Wine Cooler
Light does not go out when door is closed. Button does depress but light stays on.
  • 2,237 Answers
If it went out before, you have a broken switch that needs to be replaced.
Posted on Nov 12, 2009
Interior light staying on
Check the knob where you turn the lights on or off. Sometimes if you twist it the dome light will come on and stay til you turn it off. Other possible is contact in door that would normally turn off the light when closed. May be worn and not depressing all the way when door closes.
Dec 06, 2016 | Cars & Trucks
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
How can I find out which door has the bad door ajar sensor?
Might try closing all doors, then open one at a time and manually depress the switches. Feel them for "click" feeling and see if by depressing fully you can make the light go out. Remember also that you have a switch which turns the lights to on even with all doors closed. And also, the driver's door sees the most use so that switch is the most likely to fail, plus those hinges wear causing the door to not close as well.
Mar 01, 2016 | Cars & Trucks
Why is light staying on and its making annoying humming sound?
The door switches are either faulty or not being depress when the door is closed, this usually means that the door and the cabinet are out of alignment
Dec 23, 2015 | In Microwave Ovens
Door ajar light stays on as well as interior lights when all doors are closed
Most vehicle door open light works by a spring loaded contact switch. The switch body acts as ground. when the door is closed the switch depress disconnecting positive from ground. Seems that one of your door switch may be bad. Look for a rubber covered sitch on the door jam you should be able to remove the rubber cover to access the switch for a good inspection.
Jan 12, 2014 | 2004 Lexus GX 470
Door ajar light stays on-inside light won't go off
One of the switches for the light is is broke. The switch is located in the door frame. When the door closes it depresses the switch button. If the button is broken or worn down it won't depress enough to shut of the light. You will have to locate each switch and test for proper operation. The tailgate probably has one also.
Aug 13, 2010 | 2004 Ford Explorer
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
161 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
