Question about Crown CE2000 2-Channel Amplifier
I have two JBL MP418-SP subwoofer amplifier modules, built by crown audio, that have puked. I bought a used CE2000 to canibalize for parts. Looking for an expert that can repair these two modules.
3 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: I have a crown ce2000 amplifier that need repair is there parts
http://www.crownaudio.com/support/techsupp.htm
Posted on Mar 27, 2009
petraman7
  • 1175 Answers
SOURCE: I have Crown ce2000,it turns off after a short
Hi...
IF all the outputs are connected right and it still does that..Take it to a tech..You have bad output transistors
Posted on Jul 30, 2009
I have a jvc sp-pw50 Subwoofer and i want to know if you can buy an adapter for the input so i can hook it up to my kenwood amp? my amp does have a regular audio jack
That would require you to disassemble the subwoofer cabinet and disconnect the the supplied amplifier.
Connecting this unit to a different amplifier would provide no benefit to you unless the on-board amplifier became damaged.
Nov 16, 2011 | JVC SP-PW100 Subwoofer
How much watts is the crown ce 2000
Depending on the configuration of speakers you have it will deliver different amounts of power up to 1950 watts when used to power a single 4 ohm speaker. Typical usage would be powering a pair of 8 ohm speakers, in which case it will deliver 400 watts per channel/ speaker.
Sep 16, 2011 | Crown CE2000 2-Channel Amplifier
I blew the circuit board on my jbl pb12 subwoofer. how or where do i find a replacement and is it expensive or a cheap part to fix/replace?
Sorry to hear that. The JBL PB12 are notorious for their amplifier module giving out. This item is not repairable nor is there a replacement (The module is potted into an aluminum heat sink). Actually, I need to clarify, as the late models used discrete components. If this is the case, either Repair it yourself (Google search PB12 Repairs) or take it to the local repair shop. (Or to a technical college with an electronics program, they may work on it!)
The best method is looking for a plate amp to replace the PB12 Amplifier - try the bash 300W. Several people have done this conversion. Be warned, you will need to do woodworking if you want to mount the plate amp on the box!
Mar 01, 2010 | JBL PB12 Subwoofer
I request a schematic diagram of crown power amp CE2000 2-Channel
The surface mount ic= MC33079D , 14 pin quad low noise op amp is likely at fault, IF the amp is NOT showing a fault light. A LM324D surface mount will
also work in a pinch. It's located on the input pcb attached to the input jacks.
Jan 19, 2010 | Crown CE2000 2-Channel Amplifier
Hi - trying to repair a CE 2000 crown amp. need parts R 33 (crown did have stock) R 36 crown said they dont see it in their list also LM4701T crown also said they dont know what that part is. i have...
I have a working CE2000, I might be able to help you identify the value of the parts....please send me pictures of the part location and indicate with an arrow.
yadsyon@yahoo.com
Aug 17, 2009 | Crown CE2000 2-Channel Amplifier
I have Crown ce2000,it turns off after a short period then on then off ect.
Hi...
Jun 27, 2009 | Crown CE2000 2-Channel Amplifier
I have a crown ce2000 amplifier that need repair is there parts available?
Parts should be available both on the secondary market as well as from Crown. What parts do you need?
Dan
Mar 25, 2009 | Crown CE2000 Amplifier
Solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
CE2000
clipping as indicated by its light? if so then you have overdriven your output. i dont know about Crown their protection but normally such indication you have problem with either your load speakers maybe shorted but still audible or maybe your input stage overdriven also.
redrivera
Mar 17, 2008 | Crown CE2000 2-Channel Amplifier
Crown CE2000 2-Channel Amplifier Logo
460 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
