Question about Goodman CLQ36AR49 Air Conditioner
My out side unit will not come on i have checked thermoastate wires capacitor and voltage and freon ,, points are not pulling in its a yr old split air from goodman
  • Goodman Master
  • 43,501 Answers
You should have 24v ac at the coil to the contactor (points) as you call them. The 24v comes from the indoor unit through the thermostat. If you manually push in the contactor does the unit run. If so, then the problem lies in the low voltage circuit somewhere.
If the indoor blower comes on when you switch the thermostat to fan them you have low vaoltage and the transformer is okay if not then change the transformer or fuse. if you have low voltage then you need to be checking for a broken wire of a bad thermostat on the cooling side. depending on your thermostat a relay can go bad in it the runs the cooling.
Posted on Nov 12, 2009
Air conditioner.
If its a mini split/ductless split its worth calling a tech. You can't buy freon legally unless you have an epa license. Also the minisplits are a bit complicated so experience is great! But.... It should be betwee 78°-95° outdoors. There is only 1 charging port. At the copper lineset that connects to the o.d. unit there should be a shraeder valve. Remove the cap, connect toyour low side port from your low side of your guages. Hook up your middle hose from your guages to the drum of freon, probably R-410-a, and open the valve on the drum. Both handles on the guages should be closed/seated. Slightly open the middle hose at the gauges by unscrewing it just a little for 3-4 seconds to bleed any air in the hose and then close it. Do the same on the low side hose for about 1 second. Turn the drum of freon over/upside down or follow the freons' charging instructions(should be on the drum/can). Using a clamp on amp meter, clamp on to the compressors common wire. Verify your compressors RLA (max amperage while operating) Turn on the cooling at the t-stat/remote to its lowest set temp. Wait 7-10 minutes. The unit should have started and operating if not you cant charge it until it has started atempting to cool. If the rla is very near its rated rla it don't need freon. If its low on freon the rla will be low. Open low side port on guages for 2-3 seconds and then close. Wait 5-7 mins. You should hear the compressor increase in speed and rla will increase also on your amp meter. This should be repeated until the rla is near the rated rla on the data plate/sticker/sheet. After charging close all valves that are open and qhickly remove hose from shraeder valve. The best way is to weigh the freon in! Or to have someone (technician) locate the leak and replace or repair. R-410a freon is a blend of freons and a leaking system will loose efficiency after recharged a few times. I can't stress enough when it comes to allowing a professional work on HVAC equipment due to the fact that most freons have an ozone depletion potential and these machine have high voltage as well as capacitors that hold a higher voltage and can release when any wire is touched at a terminal. Be safe!!!
Jun 17, 2015 | Fujitsu Heating & Cooling
Wiring- Connecting wiring on replaced fan motor
Your new fan motor should have a diagram with it or at least printed on the side of the motor, that will help a lot from your end. As for me, I don't know what unit you have, so I will try to help you with just the basics.
Your old motor probably had 3 wires. One went to the contactor, that is the "Line Voltage", one went to the Common terminal on the old capacitor (COM), that's the other "Line Voltage" wire, and the last one went to the "FAN" terminal on the old capacitor. The reason the old capacitor looks different is because it works for both the compressor and the fan motor (split capacitor). You still need this hooked up for the compressor to work.
The new fan motor.
These vary in brands and wiring so I can not tell you the colors without knowing exactly which motor you have. On the new motor wiring diagram, you should see the "Line Voltage" as described above that 2 of the wires are ran to each other (just on the diagram, not wired together on the unit). This is your power wire that goes to the contactor on the unit, usually black, and your Common wire that runs to the capacitor. You can still run this wire (COM) to the common terminal on the old capacitor since you still have to use the old capacitor for the compressor and the common terminal should still be jumper-ed from the contactor to the (COM) terminal. Then you will probably have 2 wires for the new capacitor, usually Brown and Brown/White. These wires run to each side of the new capacitor and doesn't matter which terminal. Then you will take a new jumper wire from the (COM) terminal on the old capacitor to the terminal on the new capacitor that has your Brown/White lead. Make sure you secure the capacitors inside the unit so not to touch anything surrounding them. Your new motor might also be a "Reversible" motor that has reversing wires also. Again, your new motor diagram can tell you how to hook these up. You have to have it spinning the right way, most of the time it is CCW (counter-clockwise).
I'm sorry I can't be any clearer on this, but without knowing the brands, models, etc, I'm in the dark. If you need any additional help, I would be glad to help! Good luck and hope you get to cooler days!
Jun 28, 2012 | Heating & Cooling
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
I have a ckL 36-1L CONDENSER UNIT BY GOODMAN I NEED A PICTUR E DIAGRAM TO WIRE UP THE WIRES FROM THE COMPRESSOR TO THE CAPACITOR TO THE CONTACTOR TO THE 24VOLT T-STAT WIRES TO MAKE THE CONDENSER UNIT...
Hi, I can tell you how to wire it, but no diagram. Take the common wire from the compressor, look on the terminal cover or straight at the terminals and you will see C, R, and S. Wire colors vary. C is common on the capacitor, R goes to herm on the capacitor, and S goes to the load side of the contactor, or outlet side, to one of the un- used terminals on either side of 220 volts. That takes care of compressor, R, Run, S, Start, and C, for Common. Low voltage wires will be 2 -18gauge wires coming off each side of the coil on the contactor, connected to the 2-wires coming from your indoor unit, 24 volts. Your off and running unless its off on low pressure switch, and then it will start when you start adding freon.I hope I have been of help to you.
Shastalaker7
Jun 03, 2011 | Goodman Heating & Cooling
Turn on ac and it takes a long while to start then goes off after 5 mins then takes ages to start again.condensor core/fins are all clean.
Hello
Do you have the correct voltage going to the unit.
Thermostat sensing bulb should be up against the cooling coil.
Possible bad start capacitor on the compressor,or low on freon.
Start capacitor will cause heat and overload if its bad.
Low freon will also make unit shutdown after a couple minites.
Some ideas to look at.
Jan 27, 2010 | LG LSC121PMA Split System Air Conditioner
Not running; msg18 mini split , defrost board blinking 5 times.
check freon to low or to high. must be charged liquid 410 tank upside down.
Dec 14, 2009 | Heating & Cooling
The compressor or the fan will not run on my condensor. had a bad storm, replaced 3 amp fuse on the 24volt system, this got my contactor coi working, could my start run capacitor be bad , even though it's...
Hi, you cannot check capacitor when it's in an energize circuit, you will have to remove wires from it to check, place ohm meter(multi-tester) lead on terminal on capacitor, it should go up all the way, then return to zero, if tester pointer(neddle) go up and stay up, capacitor has a short, (no good), but first, it's possible your system has a freon leak, if system is undercharge, it won't start, low pressure cut off switch will prevent system from starting, even if there's voltage,connect freon gauges, check pressure, add some freon, if it starts, you've got leak somewhere in system, check all connection for oil, where ever there's a freon leak, there're usually oil, dont change capacitor or anything yet, first add some freon, it should start, also if system is 208, or 3 phase, check breaker or fuse, check voltage mains on unit, make sure you have correct voltage, you could have a faulty breaker too, reset breakers. good luck
Aug 08, 2009 | Weather King 10AJA2501AH Air Conditioner
Power to compressor but compressor will not start Unit is split system-2.5 ton, freon is good
i would check the capacitor( shiny little round or oval can) if bad get an exact replacement(mfd and voltage) if it is good i would try adding a boost capacitor(increases starting torque by 300%)
Jul 30, 2009 | Ruud Matching Split Air Conditioner
Ac unit fan does not turn unless i force it to turn. also not producing cold air
If the fan just hums and if you spin the fan and it runs, check out the capacitor, it is bad. Most condensing units have a split capacitor, for the hermedic unit and the fan. If the compressor runs the dual capacitor is bad on the fan side. Your choice buy the dual capacitor, or just buy a single capacitor for the fan part of it. Make sure the voltage rating and microfarad ratings are the same. They will be marked on the old capacitor, as will fan (for fan), and herm for compressor). THATS 220 VOLTAGE YOUR WORKING WITH, BE SURE THE POWER IS OFF!!
Jun 22, 2009 | Goodman Heating & Cooling
Wires
2 brown wires go to a split capacitor if you have a dual cap which has three terminals marked comp fan com if u have this type of capacitor then the brown wire goes to fan and the brown and white gets capped with a wire nut. whenever replacing a fan motor you should also replace the cap or at least check the capacitance to see if it is still good. you have to check it with a meter that test microfarad.you can get a permanent split capacitor and mount it in there then u use the brown on one side and the brown and white on the other side it only has 2 terminals.
May 31, 2009 | GE Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
162 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
