Question about Panasonic PanaFax UF-8000 Laser Fax
Message; remove misfeed paper, when its not misfeed paper at all
    President:
  • 3,085 Answers
One of the feed switch actuators is trapped down. Remove the toner cart and check underneath.
Open the rear door and check there too.
Posted on Jan 06, 2010
IT IS GIVING ME CLEAR MISFEED (A) I DID THAT AND IT STILL TELLS ME TO CLEAR MISFEED, I EVEN TURNED AND UNPLUGGED IT AND CLEARED AND CLEANED AND STILL HAS THAT MESSAGE
you may have a bad switch. sometimes paper hides behind the drawer. remove your paper cassettes and look begind them for a paper
Jan 06, 2011 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    REMOVE PAPER MISFEED
    There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe you knocked one off?
    Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
    MACHINE DO NOT COPY AND GIVE THE FOLLOWING MESSAGE: (A ZIGZAG SYMBOL) WITH "FOLLOW THE INSTRUCTION"
    Sounds like the 'Clear misfeed' symbol. Open the front cover and follow the pictorial diagram instructions to check your paper feed path for jammed paper. Remove misfeed, and close covers. This should reset your machine.
    Jan 30, 2010 | Ricoh Aficio 2018D All-In-One Laser...
    Sharp al-1631 misfeed light will not go out
    This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
    Make sure you also try unplugging and replugging the copier from the wall.
    Hope this helps
    May 19, 2009 | Sharp AL 1631 Copier
    The machine gives a false error message.''misfeed A :internal path
    Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
    Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
    Amessage '' misfeed detected'' please remove the .... from 0
    before i can help you you need to tell me which brand and model is the machine.
    The Message "misfeed detected" means that a paper is bee jammed inside of the copier so you should open some door and remove the paper which has been jammed inside of the copier.
    Because of that i need the brand and model of the copier for i to be able to help you and tell you what to do
    Jan 29, 2009 | Office Equipment & Supplies
    Paper Misfeed Problem
    When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
    Thanks Jason
    Aug 16, 2008 | Office Equipment & Supplies
    Panasonic PanaFax UF-8000 Laser Fax Logo
    163 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    CheckitRight
    CheckitRight
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
