Question about Gateway 2520915 Keyboard
Wireless Keyboard not connecting
I can't seem to get my wireless keyboard to synch with my computer - the instructions say to press the connect button on the side for 3 secs and then the connect button on keyboard...it worked with my mouse but not with my keyboard, Please help
  • Anonymous Jan 23, 2008
  • Anonymous Mar 12, 2014
    Wireless keyboard won't connect put in new batteries
  • 151 Answers
Check driver for it
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this then do this
  1. if it is not work then do above procss and select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
Posted on Mar 16, 2008
Labtech ps2 wireless desktop
Usually, the connect procedure for Labtec is, that you press the small connect button on the receiver, (which on some models, then starts blinking).. Next, you press the connect button, on the bottom of either the mouse, or keyboard.. then repeat this, for the remaining unit.
Note: You might have to connect the PS2 receiver BEFORE starting the PC, and also might have to install the drivers, to get the multimedia-keys to work ! Good luck!
Mar 19, 2014 | Labtec Wireless Desktop Keyboard/Mouse...
Gateway wireless keyboard detection
Insert the installation CD that came with your wireless keyboard set into your computer's CD-ROM drive.
Use the CD to install the drivers for the wireless peripherals.
Insert batteries into the keyboard .
Use a screwdriver to remove any screws that hold the battery bay covers closed.
Connect the wireless signal receiver to your computer.
Receivers for wireless keyboard and mouse sets usually use a USB connector.
Your computer will automatically detect the receiver.
Turn on your keyboard if the devices have power buttons.
Press the "Sync," "Connect" or "Pair" buttons on the keyboard , depending on your model.
If present, press the "Connect" button on the wireless signal receiver as well.
Your wireless keyboard set is now connected.
hope this helps
Oct 13, 2012 | Gateway One Computers & Internet
No communication with keyboard
Well it seems that you are using a wireless keyboard, if it is a wireless keyboard then you need to do a re-search to get it work again. There is a wireless device connected to your computer USB port that use to make a communication between computer and keyboard. and there is a button on that device all you need to do is press that button and press another button located on the keyboard backside. sure it will helps you.
Good Luck
Oct 06, 2011 | Computers & Internet
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
My Dell wireless keyboard has stopped working. The optical mouse is still working, but the keystrokes are not being transmitted from the keyboard. I have already replaced the batteries and checked the...
Underneath the keyboard is a little 're-set' button. When you push this it re-synchs with the wireless antenna. Make sure you hold it down long enough fo rthe keyboard to synch, usually about 5 - 7 seconds.
Dec 19, 2009 | Dell Wireless Keyboard Optical Mouse w0147
I have a microsoft wireless keyboard and mouse I am trying to connect to my computer I have the mouse working fine but it seems the keyboard is not turning on. I can not get it to connect with the...
It means, your batteries are dead so need to be replaced on keyboard once you replace those the you got to turn it on and once lights comes up then you to to press wireless button for 5 seconds.
once it starts blinking then you got to press wireless button of receiver (bluetooth stack) and once it blinks then your keyboard should be detected automatically.
please post back if any thing changes and vote all answers.
Good Luck.
May 11, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
I opened up the Logitech Mouse and Keyboard Settings, turned my keyboard off, changed out the batteries and turned it back on. It then detected the Keyboard and asked for a password, I entered in the password, it said it was rebooting it and asked for another password which I entered (both passwords were given to me in the Settings). Now it is working just fine! Not sure if you have tried this but it might work for you.
Jan 04, 2009 | Logitech EasyCall Desktop? Keyboard and...
Logitech keyboard quit working
hi,
almost every wireless keyboard / mouse has a connect button somewhere. its located on the bottom or on the side. what you need to do is to press and hold on the connect button to synch the device with the transmitter connected to the computer. if the transmitter on the computer has a connect button you might need to press them both at the same time. do the same if the wireless mouse stops working.
Oct 16, 2008 | Logitech Cordless Desktop MX 3000...
Wireless keyboard> how do i set it up?
where you have connected the wireless keyboard, probably it's a small stick coming from your computer or a cable to an infrared reciever, it probably has a little button
Dec 04, 2007 | Motorola Mobility Mobile PhoneTools 3.0...
Vp6210 wireless connection
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Sep 01, 2006 | Interlink Electronics VersaPoint Keyboard
Gateway 2520915 Keyboard Logo
1,471 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
