Question about Motorola Mobility L6 Cellular Phone
I have got a Motorola mobile phone and I have got picture messages in my inbox and when I open them they say "Unable to download" what do I need to do to be able to open these? Many thanks
Plz guide me, my nokia3110c, has a problem with inbox opning. on opening of inbox nokia phone is resarted. there is 1.5kb file remained in inbox after deleting all the inbox massages. plz help......
The last thing you need to do is to flash / update the phone so Click here1 if you want to do it by yourself or contact mobile repairing shop.And here is your 3110c file.The particular file which you could not able to remove might infected by virus or corrupted. Good luck
Jan 13, 2012 | Nokia 3110 Cellular Phone
How do I get my Motorola W490 to let me see pictures I receive in text messages? When I try to open the text message/picture, it says unable to download.
your phone not support picture message
it mean you can see your picture message
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Motorola Mobility W490 Cellular Phone
Can't send text w/pictures or open texts with pictures
If you want to send message with a picture attached, it means you are sending MMS..To send or recieve MMS you should should have a MMS SETTINGS, think you dont hace MMS setting in your phone.
My advice is ask the operator to send the MMS settings, they may send it through air and save it to your mobile, restart your mobile and you should able to MMS after then...
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Unlocked Motorola phone can't do multimedia messages
i have the same problem but i cant send or recieve pictures,audio files,ect. and also i constantly have a message icon that will not go away
Aug 10, 2009 | Motorola Mobility W510 Mobile Phone
Cant open any messages sent to my phone inbox
You need to check the settings then .....
Message > Menu > Message Setup. Fill in the required and you should be away.
Master Clear and Master Rest get rid of all your pictures, ringtones, videos and address book
so beware of this !
Aug 06, 2009 | Motorola Mobility HS850 Consumer Headset
MOTOROLA KRZR KM1
to fix this problem you will need to contact your network service provider and get them to resend your gprs settings to your handset, this will than allow you to use the requested features on your mobile phone, because it sounds to me as though, either the gprs settings have not been set up or they have been deleted, hope this helps.
Mar 26, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Download texts messages onto computer
You will need to download a software called mobile phone tools to get this done. You will also need a data cable or a bluetooth dongle on your PC so that you can connect the phone. http://www.bvrp.com/ENG/products/
After downloading and installing the above software follow these steps to transfer the msgs to PC.
Open Mobile Phone Tools
Press F3 (for transferring messages from outbox) or Press F4 (for transferring from inbox)
Select messages you want to transfer
Select EXPORT
Choose format/destination. I would recommend txt format as it is real quick.
Hope that helped,
Sai.
Jan 12, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Text messaging
am unable to send SMS messages? space.gif space.gif answer.gif As a set limitation to the phone's design, if the SMS Inbox is consumed, the phone's alternative is to send as an MMS.
If a customer is calling and their phone is sending SMS messages as MMS messages, please advise them that they may have an excessive amount of SMS messages in their inbox. Advise them that deleting some or all of these messages should correct the problem.
To delete messages:
  1. Press Menu
  2. Scroll to and Select Messaging
  3. Press Options
  4. Scroll to and Select Cleanup Messages
  5. Scroll to and Select All, or Inbox
  6. Press Yes, to Delete Messages
Oct 18, 2008 | Motorola Mobility RAZR V3
Motorola RAZR mieterious message icon
Check and see if someone has sent you a picture message that you haven't downloaded yet. If you have one, it will tell you that you haven't opened it, and all you need to do is download it if you want that to stop. Or you could just delete the message.
It's not a big problem that will mess up your phone, it's just telling you something. (:
Jun 21, 2008 | Motorola Mobility RAZR V3
Message not able to be opened or read.
Do you have proper signal strength? If so, i would be willing to bet that the phone doesnt have enough memory left to download the message. If you have good signal and it wont work then try deleting a few of the pictures or vids that you allready have on your phone then turn the phone off then back on to try downloading it again... Hope this helps
May 19, 2008 | Motorola Mobility RAZR V3
Motorola Mobility L6 Cellular Phone Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
