Question about RIM BlackBerry Bold Smartphone
Calendar program on blackberry stopped working. I was entering a date and the calendar stopped responding. Hit the red button to close and now the calendar won't open or respond.
How do I set the time and date on a canon p170-dh
Press the Date and Time button on the calculator. It is to the right of the Feed button and has a small calendar and clock on it. To set the date, press the button once to display the factory supplied date and hold down the Equal ( = ) button that is two buttons below Date and Time until the screen flashes. Input the correct date. Ex: August 20, 2010 would be entered on the numerical keyboard of the calculator at 08202010. When finished, hold the Equal button again. Do the same for the time.
To sum it up:
Press Date and Time button
Hold = button until blinks
Enter date or time
Hold = button again until blinking stops
Aug 03, 2010 | Canon P170-DH Calculator
My backberry pearl freezes up and when i take the battery out it takes an hour for it to load and freezes more
This unit is prone of freezing up due to low memory. Check your free space on your phone,make sure you are cleaning memory,by purging cache memory etc. Also when you leave a program actually select"CLOSE" button.Most people close the applications by pressing the escape or red key. This does not close the application has a CLOSE option. For instance if you are in the calendar hit hit menu key and scroll down to the bottom CLOSE is listed. Go through each application and press close. Go into the cache operations clear all categories and hit escape it will say cleaning memory. Go to options - security - memory cleaning - enable it. The BB will now clean memory when idle for 5 minutes. Hope it may helps,feel free to ask whatever the result.
Regards:
VOTIT
May 21, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
How do i fix app error 523
This happened to me because of a theme error. I was using the "bbdimension today" and found my phone locked up in a reboot cycle in the morning. After digging around I found someone that suggested looking through modules with the javaloader/jl_cmdr software and removing anything new. This theme was the first thing i removed and my blackberry powered right up.
You have to get JL_cmdr package from pinstack:
blackberryforums.pinstack.com/downloads.html?catid=5&linkid=452
Then install it on your system. Now that your blackberry is in a reboot cycle, you have a very short amount of time to actually run these commands while the system is booting up and you have the white screen with the hour glass. So you may have to pull the battery several times while doing these steps and run one command at a time.
(in windows xp)
1) click "start" -> "run" -> type in "cmd" and hit enter to get to dos prompt
2) type in the following:
"c:\Program Files\JL_Cmder\JavaLoader.exe" -u -w<passwordifyouhaveone> dir > mymodules.txt
this will create a file in your current directory called mymodules.txt. open it and look through your modules. in my case the culprit was "net_rim_theme_bbdimension_today_320x240_b". This theme displays my messages and calendar on the front page of the system. I'm guessing that since it has to recalculate the calendar each day, there must have been something about the tasks that I set up yesterday to show up in my calendar. It must have hit a snag after the date changed at midnight, and it got hung up. Could have also been something about my messages.
3) once you determine which module(s) you want to delete, we'll need to save it just in case we want it back later. In my case the module was "net_rim_theme_bbdimension_today_320x240_b"
the full command to save it was:
"c:\Program Files\JL_Cmder\JavaLoader.exe -u -w<passwordifyouhaveone> save net_rim_theme_bbdimension_today_320x240_b
4) now erase it!
"c:\Program Files\JL_Cmder\JavaLoader.exe -u -w<passwordifyouhaveone> erase net_rim_theme_bbdimension_today_320x240_b
On my blackberry, it said that this was an active module, so I had to force it with the -f switch. Total command was:
"c:\Program Files\JL_Cmder\JavaLoader.exe -u -w<passwordifyouhaveone> erase -f net_rim_theme_bbdimension_today_320x240_b
After the module was erased, the blackberry restarted and my system came back to fully working status.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Camera display to clo0se applications to use camera,how?
When you press the red or end button to close a program it does not exit but rather minimizes it. you need to hit the menue button the blackberry key ( the one with all the dots next to the trackball) and select close or exit
Feb 22, 2010 | AT&T Blackberry Curve 8300 Smartphone
My blackberry is super slow, and is always thinking.
Pulling the battery to reboot will clear the memory is the most recommended and easy thing to do.
Ensure that you close all of your programs that you have been running. Hitting the red power button to close programs doesn't always close them, just puts them in the background. select the blackberry button next to the green button and hit it again and go to switch applications.
Then select apps that are running in the background and click the blackberry button again to bring up a menu and select close.
You will definitely want to turn it off sometimes. Even if it's a standalone OS for Blackberries, you may want to reboot it to free up some hoarded memory.
You may also have a sluggish battery. So see here.
Also see John Clark's guide on memory here:
http://www.blackberryforums.com/general-blackberry-discussion/112029-losing-call-logs-sms-emails-optimize-your-bb-how-setup-max-free-memory.html
Sep 28, 2009 | Verizon Communications BlackBerry Pearl...
Desktop Manager stops before completing synchronization
Usually this has to do with a large attachment, reoccurring appt., or corrupted date record in Calendar. Do a search for a file on your computer called scanpst.exe. Run it and point it to your Outlook.ost file location. Be sure Outlook and Desktop Manager are closed. It will diagnose and correct any errors with your Outlook Mailbox, and hopefully correct this issue. When you search for the files, be sure to look in hidden files as well.
Mar 25, 2009 | RIM BlackBerry Pearl 8100
7" Trutech digital photo frame Calendar
Use the Navigation Buttons to select "Calendar"; press Enter to confirm. To set the date, press the Stop Button and then use < and > Buttons to adjust the year and the arrow down and ^ buttons to adjust the month; press the Stop Button again to confirm. Then, use the Navigation Buttons to select the current date on the calendar display and press Enter to confirm. To exit press the Menu Button.
Nov 07, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Changing Time
Hey peoples this worked for me :)
On the main phone
- hit the "PROGRAM" key
- then key in **
- it asks for a password key in 1234
- then key "NEXT"
- then key "ENTER" (this is to set the date)
- then key "NEXT" (this is too set the time)
- once the time is correct hit the "ENTER" key at the bottom of the phone.
Mar 09, 2008 | Panasonic KX-T7630 Corded Phone
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Nov 30, 2007 | Canon P23-DH Calculator
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
RIM BlackBerry Bold Smartphone Logo
46 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
