Question about Homelite Leaf Vac Attack
Idle good on ground but pick it up and it stops
  • 486 Answers
Therory #1
Electrical short or ground
You might have a wire to the coil for 'kill switch' in the handle assembly that is connected to the Off-On switch and is being pinched by something when you pick the unit up. If you pick it up by the body or base, does it die, or is this only when you pick it up by the handle.
If you pick it up by the handle(only), I suspect a pinched wire:
Therory #1
If you pick it up by the base, I suspect it is fuel related:
thus therory #2
Theroy #2
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 12, 2009
Static stops when i stop moving
The radio may have been installed incorrectly or the squelch setting is incorrect or the antenna connection is not properly grounded
Nov 09, 2013 | Midland 1001Z 40-Channels Base CB Radio
My 2003 eclipse will idle fine but when put in reverse or drive it wants to die.
You should first get the engine scanned for trouble codes.
Try a new fuel filter, or have the fuel pressure tested. If fuel pressure is good, try some injector cleaner. If still no help, time for a tune-up with new plugs and wires, filters, pcv valve. If still no help, possibly the catalytic converter may be plugging up, or your egr valve needs cleaning. Could be a lot of things-you just have to start eliminating one by one. short of a shop running diagnostics and testing to find the problem. Good luck.
Jan 06, 2013 | Cars & Trucks
Have miss at idle and when the trans need to down shift
You.ve got me confused!!! You have a miss at idle, but at idle the miss stops, and when you step on the gas the miss stops. It sounds to me that the miss is stopping under all conditions - so what is the problem?
Apr 24, 2012 | 1998 Chevrolet S-10 Pickup
I purchased a 1997 chevy blazer ... looks great interior and exterior... but when I drive and stop, i have to keep 1 foot on gas pedal and one foot on break. what do i do ?
Here is the common cause of surges, cold stalls, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours.
To correct this problem get a can of throttle valve cleaner (it is made by CRC) from the local auto parts store, spray it into the air intake of the engine until you have used about half the can, you will need to hold the idle up while you do this, it will try to stall, after this shut the engine down and disconnect the Negative (-) battery cable for 5 minutes. The intake is know clean, if you continue to have the stall out the idle speed control valve may be defective and requires replacement.
Mar 04, 2011 | 1997 Chevrolet Blazer
1997 dodge ram idling problems
check the iac (idle/air valve) it controls the idle speed during the time the engine is started or coming to a stop. iac valve is located behind the throttle body . hope this will help you with your problem!!!!
Apr 16, 2010 | 1997 Dodge Ram 1500 Club Cab
I need to know how to rewire the ignition system
Hi and welcome to FixYa,
On your requirement to "...rewire the ignition system..." of an XS650, below basic ignitor wiring scheme maybe of reference:
  • white / red - from pick up;
  • white / green - from pick up;
  • black / white - from pick up;
  • orange - to ignition coil;
  • red / white - IGN + 12 from engine stop switch ;
  • black - ground;
Good luck and thank you for asking FixYa.
Nov 14, 2009 | 1980 Yamaha XS 650 G
93 chevy 1500 v6 keeps dying out.
Connect a voltmeter set on ac volts to the pickup coil wires (disconnected from the module) and crank the engine.
2. The pick-up coil output should be more than 0.7v AC. If not, replace the pick up coil and distributor shaft.
3. Visually inspect the condition of the magnet on top of the distributor shaft to be in good condition. If not, replace the distributor
1. Disconnect the set timing connector or ground the Tan/Black bypass wire.
2. The check engine light should come on and code 42 should set.
3. If the engine stops stalling, disconnect the pick up coil connector at the Ignition Control Module (ICM).
4. Check acv output from the pick up coil while cranking the engine at a normal cranking speed.
5. If output is less than 700 mv replace the distributor shaft with a new one.
Oct 13, 2009 | Chevrolet 1500 Cars & Trucks
Where does the battery ground wire connect on the frame of the car on a 1999 Toyota SR5 4 runner located?
if it was mine i would ground the engin and the frame to the black wire. that will stop the head lamps from dimming at a idle... good day and good luck saw
Jul 07, 2009 | 1999 Toyota 4Runner
P0340 CODE COMES UP,SENSOR REPLACED CODE STILL COMING BACK.IF ENGINE IS REVED ABOVE 1500 DASH LIGHT GOES OUT BUT WHEN ENGINE IDLES DASH LIGHT COMES BACK ON.
i have 2000 cadillac deville runs really good it has a po340 engine code runs good b when i come to a complete stop the engine idles up and down only at a complete stop what do i need to do
Oct 22, 2008 | Cadillac STS Cars & Trucks
Homelite Leaf Vac Attack Logo
185 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
