Question about EliteGroup P965T-A Motherboard
Bios not loading when hitting DEL
I'm trying to access the BIOS to change the device startp-up so I can do a fresh Windows Install from CD.
Upon powering the machine I get the "Press DEL to enter startup" message but it doesn't work. I have tried F1, F5, F8, F10, F11 and even a a second keyboard and still nothing. What can I do ?
    Brigadier General:
  • 6,966 Answers
Have you tried using a PS/2 keyboard? Or the other way around, a USB keyboard.
Additionally you can try doing a reset on the motherboard by temporarily relocating the jumper on the CMOS reset pins (JP1 close to the Lithium battery) from 2-3 to 1-2 for a couple of seconds then back. Normally, once performed, the motherboard on the next boot will revert to default and auto request a CMOS setup. Alternately you can also temporarily remove the battery for about 15 minutes.
If the USB and/or PS/2 KB nor the CMOS reset does not allow you to enter the BIOS setup, perhaps you need to return the board for replacement since this is indicative of MB failure.
Hope this be of help/idea. Pls post back how things turned up or should you need further information.
Good luck and kind regards.
Posted on Jan 08, 2008
How do i access the boot menu on a Vizio All in one PC Model CA24-A0. Im trying to do a clean install of windows 7.
press f7 key ,select usb storage from start up menu and press enter ,follow steps,hope this helps :)
Oct 15, 2014 | Vizio All-In-One CA24-A0 - Core i3 3110M...
Im trying to change my hard disk but cnat reboot my pc with my pc using cd rom my cd rom is toshiba sd-r2312
You need to go into your bios and set your boot device priority. It's set to boot to the hard disk before the CD. You need to change that so the PC will try to boot to the CD first.
To access the Bios, you will need to it the key you are prompted to hit "to enter setup" You should see this while the machine is booting.
Typically you tap either F2 or Del to get into the bios. Once you fine the Boot device priority and change it, you will need to hit F10 to save your changes and exit.
If this does not fix your problem, you may have a problem with your cd drive. Hope this helps.
May 11, 2011 | Computers & Internet
I want to install windows Xp to mya IBM 300GL.. But, I couldn't boot from CD... what i have to do???
start your PC and press or hit the DEL or F2 key to enter into CMOS setting and set your first boot device into DVD or CD. or in the CMOS / BIOS setting just simply LOAD THE OPTIMAL DEFAULTS OR LOAD SETUP DEFAULT and save and Exit.
Than you
Just leave comments
Mar 15, 2011 | IBM PC 300GL PC Desktop
How to test a hard drive to check controller cannot load or format mine or from cd and do not have boot disk can you help
What is ur OS and board? Upon starting click on "del" to go to BiOS and go "BOOT" sequence, choose CD ROM as ur 1st boot sequence! Exit w/ save changes! Now ur ready to install a new Windows OS, insert a OS cd and re start ur desktop! upon starting "START CD ROM" click on "enter"! Let ur windows do everything and follow the instructions!
Nov 08, 2010 | Computers & Internet
Trying to reformat and load my computer for a fresh start. When I reboot to load Windows the screen goes to a small box saying "input not supported". How do I fix this???
visit my site
it has all details on how to reset to facotry setting.....format and reinstall Win etc
you may have to make changes to BIOS to boot from CDROM a 1st Boot device....
press F1, F2, Del, Esc, F12 key other one that brings up the BIOS screen there look for Boot seq....disable HDD and floppy, enable CD ROM drive and make that 1st boot need to change it back to HDD the1st boot device later after loading Win....
once you boot from CDROM then follow inst from my site to format HD....and install XP
all the best
pls feedback and comment on how u did
Nov 07, 2010 | Acer AL1916W 19" LCD Monitor
How do I re-format my acre aspire 5610 & install XP.
go to bios (hit del on start up) rearange boot sequence , that first boot device is cd drvie ...put winx xp in you dvd /cd drive
restart computer when it says press any key too booot from cd hit enter
žand it will start procedure for checking you configuratin and you will come to the section when it will post you your installed hard drives, format drive and install fresh copy iof xpp it is really streath forward can mistake, just read.:)))
Nov 08, 2009 | Acer Computers & Internet
Mnutey iuyoiu
Check the BIOS ("del" key upon start-up or "F1, F2 or F10" depending on system to access the menu). Check for audio setting (may need to scroll through menu categories to see if onboard audio is enabled). If disabled, try to enable it by hit spacebar, left/right arrow key or + - keys to change setting. If it is an add-on sound card you may need to install or re-install the drivers and in this case the onboard audio should be disabled in BIOS.
Sep 12, 2009 | ASUS K8V-MX Motherboard
Changing BIOS priority on toshiba satelite 5005-s504
as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
It's probably disabled in bios. Find out which key to hit during startup to enter bios (usually del or F2) and look for 'onboard devices' or something similar. Your soundcard will be in there.
Remember to save your settings as you exit bios. Drivers for the card should automatically install upon logging back into windows.
Hope this helps,
Mar 14, 2008 | Computers & Internet
EliteGroup P965T-A Motherboard Logo
132 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
