Question about Hotpoint RVM1325WW Microwave Oven
Microwave is totally dead but has power to it.
Hotpoint RVM1325WW Microwave is totally dead but has power to it.
  • 460 Answers
The kliestron is most likely bad or the stertup solenoid is stuck. also could be the control module needs replaced...
Posted on Nov 12, 2009
How do I change the fuse?
On most GE/Hotpoint models, the control panel assembly will either tip down, or pivot sideways for access to the components behind it. Screws holding the top air deflector might have to be removed in order to gain access to the control panel mounting screws. I recently junked-out a similar model. The main fuse was near where the power cord enters the cabinet on top. Avoid contact with any of the high voltage components.
May 07, 2014 | Hotpoint RVM1325WW Microwave Oven
Error message of "F3" appears
F3 or F4
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Keep us updated.
Jul 10, 2011 | Hotpoint RVM1325WW Microwave Oven
We have a Hotpoint RVM1435WJ01 above the range microwave. We lost our electricity one day due to an outside electric wire splitting - when the electric company fixed the wire, the power came back to...
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
Mar 21, 2011 | Hotpoint RVM1435 Microwave Oven
Need owners manual
You can download the owners manual in PDF format from the manufacturer's website by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 06, 2010 | Hotpoint RVM1325WW Microwave Oven
Clock frequently goes blank and needs to be reset
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
May 21, 2010 | Hotpoint RVM1325WW Microwave Oven
My microwave doesn't heat things up. It also makes a noise about 2 seconds after you start it up. Is it worth fixing? Or is it time to replace it?
depending on the age of the unit i would replace it
the most common issue for this call is the hv transformer and magnetron or diode, any one of these could be bad and making the other ones go bad
mic's are tough to call which is bad in person, i would be even harder pressed to nail it down other than one of those three or all of them
for the cost id just replace it
Oct 22, 2009 | Hotpoint RVM1325WW Microwave Oven
I replaced the light bulbs but they still do not come on and the vent fan will not come on either?
the fan and the surface lights are run through the control via the touch pad. if you tried to replace the bulbs without unplugging the unit 1st you probably shorted the board. this can be checked by lowering the touch control panel by first removing the vent above it to access the panel screw. at this point you can observe the control for burn marks
May 17, 2009 | Hotpoint RVM1325WW Microwave Oven
Hotpoint RVM1325WW Microwave Oven Logo
266 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
