Question about Air Tools & Compressors
How do I install Aquastat to Hot water recirculating pump? I see two yellow, two green a black and a brown wire. Which one goes to the timer?
  • 11,896 Answers
Plumbpedia™ 2: Grundfos Hot Water Recirculating Pump Timer Setup how do I install Aquastat - 9k= play_c.gif 7 min - Sep 4, 2008 - nav_logo7.pnhow do I install Aquastat - nav_logo7.pngi nav_logo7.png nav_logo7.png
Marty Hatley demonstrates how to set the timer and aquastat on a Grundfos hot water recirculating pump. For more information on this plumbing video ...
www.youtube.com/watch?v=URJ_-u6uDoI
Posted on Nov 12, 2009
Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
Wiring problems with Kia stereo
The simple solution would be to go to the source where she bough the system
Dec 11, 2014 | 2001 Kia Spectra
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/How-to-set-timers.html
Jul 17, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
No water is coming out of faucets and all i did was accidentally turn it a little bit what should i do?
Ok I see your re-post.
If I understand correctly, no water is coming out of any faucet.
No cold water and no hot water.
1) First of all, cold water side of water system is totally unaffected by recirculation pump or timer on recirculation pump. Faucets are connected directly to cold water line that enters house from outside, and that line does not come in contact with recirculation pump.
2) If you have no cold water, check with neighbors to see if they have water.
3) Next, go outside and check ALL outdoor spigots and see if water comes out.
4) Is it possible that you have a frozen water pipe?
Do some checking and then repost another question.
I will be here until you get it fixed.
Add a comment also to directly contact me.
Feb 14, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Where can I get the wiring diagram for the Laing Autocirc? I want to wire in a momentary switch so that when I am ready to get in the shower I hit the switch and the pump runs until the water is warm and...
If you have the same Autocirc product I have, then it cannot be taken apart. The timer seems to be connected and sealed together with the pump. If yours is different, answer back with the wires that you can see and we'll see if the timer can be by-passed.
With the ordinary Grunfos-type pump that is not on a timer, you can add a switch and have the pump work on demand as you describe.
And they make a product that does the specific job you describe. It's called a Demand Pump. Link above shows two different types at page bottom.
I have not tested either Demand Pump shown. They operate on-demand ... when you activate the pump, the pump quickly brings water over from the hot water heater.
So the Demand Pump has a higher volume pump than the Autocirc or Grunfos.
I question a two things about the Demand Pump. 1) How will the increased pump pressure affect local pipes, especially supply tubes under a sink. 2) How HOT does the pump get? If pump gets hot, and it is located under bathroom sink next to paper goods, then that is a hazard. Some regional building codes don't allow ceiling light bulbs in closets because the bulbs get hot and start fires when people pack their closets full.
Oct 23, 2010 | Laing Thermotech Autocirc Undersink...
Does it matter which wire, red, black goes on l1, l2?
"new wire", brown, blue, green, brown is what we call
HOT, that goes to the fuse, "old wire", red, black, green,
red is what we call hot, that goes to fuse, and green in both are earth.
Dec 06, 2009 | Hayward 1.5 Hp Northstar High Performance...
Need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Apr 04, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
New Timer--New Problem
Sound like you connected the timer up wrong, from my drawing check the following connections to the timer.
terminal 12 & 26 - Black (linked) mains supply
terminal 17 yellow/red (from rinse switch)
terminal 28 grey (from water level switch)
terminal 15 light blue (advance rinse switch water level switch)
terminal 27 brown (door switch)
terminal 25 brown (door switch)
terminal 62 green/black (motor)
terminal 7 red (motor)
terminal 32 yellow (motor)
terminal 9 blue (capacitor /motor)
terminal 8 white/yellow (motor) and white (water solenoids hot and cold)
terminal 71 pink (water selector switch and hot solenoid)
terminla 72 purple (water selector switch and cold solenoid)
terminal 70 white/blue (water selector switch)
Watch the light blue wires as there are several of them!!
Dec 12, 2006 | Admiral AW22 Top Load Washer
Air Tools & Compressors Logo
93 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
