Question about Sony Playstation 3 (PS3) Console
I have the Read disc error that lots of people seem to have. It won't read any discs at all. I have tried to clean the lens and I've been advised to wipe the system and start from the beginning, which i have done but here's the other problem. My controllers wont register. At the start up it says "Plug in your controller with a USB cable and press the PS button but when I do that the lights start flashing as if its charging but pressing the PS button doesn't do anything. It would be great if you have any thoughts on this. Regards Henry
  • fadeal Nov 12, 2009
    Thanks for your help. The disc problem is still there and it's feeling to me that I will need to get the drive replaced. My next problem is I rang Sony about the controller problem and they said they never heard of it! Why the hell didn't they tell me about the controller reset button, I mean as if they didn't know about it. They said it would be £99 to replace the drive and £129 to replace the whole unit. The point being I DONT TRUST THEM!! I don't want then to give me another unit that will break in 6 month (They only supply a 3 month warranty)
    Anyway, Thanks for your help.
    Henry
  • Sony Master
  • 13,433 Answers
For the disc issue, the blue ray drive is most likely dirty or its failing, if you are in warranty, then contact sony to get the drive repaired / replaced for free.
If you are outside of warranty the repair is 150. you can try taking apart the console, and cleaning the lens with a qtip - and alcohol. Naturally taking the console apart will void the warranty.
this video shows how its done on a PS2, it is the same thing on any play station or any cd/dvd drive.
http://www.youtube.com/watch?v=wGk3UltJ0s0
If the problem remains after you have cleaned the lens, then you could try canned air, blow all the dust out from the drive that you can find, and carefully even from the area / inside where the laser lens is.
if it still doesn't improve then the optics might need to be replaced, or the whole drive.
As the blueray drive is not cheap, you could send it to sony as I recall they will fix it for 150 (the blue ray drive costs something like that)
And then the controllers, they should have a reset button on the back of them, leave them on the usb to charge for 2 hours so that they have enough power.
reset your console and your controllers a few times until they start to work.
Let me know if you need further assistance.
Thanks,
Ekse
Posted on Nov 12, 2009
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
The last week the DVD player isn't working. In some cases, it will spin the DVD (and I've tried multiple DVDs to be sure) and then display the error message "bad disc". Other times, it...
Hi kjones1021,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the optical lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc, this is because of the movement of the optical lens back-and-forth. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the spindle motor - Check the spindle motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 09, 2011 | Philips PD9012/37 DVD Player
Won't read my disc?
Hi, If you are experiencing disc read errors. Nintendo is upgrading inbound and outbound shipping to expedite the total repair process. There is no cost for the repair or shipping. Please note: returning the game to the retail store will not solve the problem.
If the Cd being played is a double-layer disc which has a large memory capacity. A very small percentage of Wii consoles may have trouble consistently reading data off this large capacity disc if there is some contamination on the lens of the disc drive. Nintendo has specialized cleaning equipment that can resolve this problem. (Please do NOT attempt to clean the lens yourself, as you may damage the system.)
Hope it helped..
Aug 18, 2011 | Nintendo Wii Console
My ps2 is getting a disc read error. It is the console, not the disc. How do I fix this? I've heard that you can clean the laser reader with alcohol wipes. Is this advisable, and if so, how should...
If it's the original, fat PS2 go here:
http://www.slideshare.net/Bravo77/ps2-repair-guide
If it's the newer, slimmer PS2.
To clean the laser lens, do the following:
Dip a Q-tip in rubbing alcohol (not dripping) gently place the q-tip on to the lens and gently twirl the q-tip.
Use the other end of the q-tip to gently dry the lens.
Hope this helps :)
Jul 16, 2011 | Sony PlayStation 2 (PS2) Console
Ps2 is unable to read disc, how do I reset the factory settings. I am hoping if I reset it that it will work
Please watch this video I have attached. The disc read error on the ps2 is a hardware problem, not something that can be fixed by a reset.Good luck!
Jul 12, 2010 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error is mainly due to worn-out,dirty lens and it can also appear because of the disc that you have inserted in your PS2......
Try following to get rid of DISC READ ERROR:
  • Clean your PS2 lens:
Watch this video first
This will help you in cleaning the lens.You can also clean your PS2 lens by some lens cleaning DISC.Make sure not to touch lens with your hand.
  • Clean your DISC:
Watch this one to clean your DISC
Thank you!!!
Nov 12, 2009 | Sony PS2 Dual Shock 2 Controller...
Disc not reading
If you're getting a Disc Read Error (DRE), it could be one or both of these things.
Your laser lens is dirty or broken and needs to be cleaned or replaced, or your disc tray is faulty and needs to be serviced.
Try cleaning the lens and see if it will read. If you can hear the disc spin in the PS3, then your disc tray is fine.
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
No disc read on dc100
There are only 4 possible solutions,
1. Dirty or faulty discs, but as you've tried different discs this doesn't seem likely.
2. Condensation has developed in the camcorder, leave it in a dry indoor temperatured place for a couple of hours and try again.
3. Dirty lens won't let the laser read the disc. Look for lens cleaning camcorderkit in a store.
4. Manufacturing error
Hope this will help you.
Jul 14, 2008 | Canon DC100 DVD Camcorder
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
