Question about JVC Everio GZ-MG30 Camcorder
My JVC Everio GZ-MG30 will not hold a charge... I can leave it charging for hours and it doesn't charge. Works fine otherwise when plugged in but no battery! HELP!
  • tony342 Nov 12, 2009
    Thanks for the response.
    I actually purchased a new battery and fully charged it (overnight) to no avail -- unplugged after charging and the camcorder would not even power up, as if no battery was attached at all. That's the troubling part, it's not that it's saying low battery power or flashing battery icon onscreen, whatever... it's not powering up at all. But it works like gangbusters when plugged in. Any additional thoughts? Thanks!
  • 770 Answers
Your battery has developed a memory. This is common with electroncs, laptops, cell phones, and yes cameras! You will need to replace your battery. To get the most from your new battery, fully charge before using the camera. Do not re-charge until the battery is all but dead, then fully charge before using. Always do it this way and you will get optimum life expectancy from your devices. Unfortunately, we tend to re-charge prematurely and even use devices while charging...which is ok, but when we do not fully charge, or we plug in before the dying end, the battery begins to develop a memory and thinks it doesn't need as much charge until eventually, the device will not work unless plugged in. Good Luck. I hope this is helpful.
Posted on Nov 12, 2009
  • Hal Hallman Nov 13, 2009
    Ok, your charging cord either has a transformer built in, reducing the voltage to the proper amount for your device, or there is a transformer in the device itself, inside the case, near the point that the charging plug goes in. What we know. We know that this transformer is functioning...evidenced by the fact that your device will work when the cord is attached. What we don't know is whether or not the transformer is getting power to your battery, or if the battery is getting power out, or a combination of the 2. First thing to check are the contacts that the battery touches when placed in the device. You can lightly clean these with a Q Tip and some denatured alcohol. Also it is important that these contacts are not bent or that they are making firm contact with the battery. If you have access to a voltage tester, you can determine if power is getting to the contacts that charge the battery when it is in place. If none of these suggestions fix the problem, then you have a power break near the transformer...if it is not on the cord...if it is on the cord, then you have a power break either between the point that the cord plugs in and the "Charging Contacts" that touch your battery, or the "Power Up" contacts and the point that those wires integrate back into the wiring that operates your device. If you are not pretty good at micro type wiring, it may be a good Idea to have a qualified tech, test these wires and make your repair. It should be easy for them to trace and a simple fix. Good Luck!
Is there another way to charge the camera so that I can turn it on and retrieve what is on it?
You will need either the camera power supply or a charged battery, if don't have a power supply for camera or a charged battery there is no way around it.
Jan 02, 2015 | JVC Everio GZ-MG30 Camcorder
My JVC GZ-MG21EK won't turn on, record, or playback unless it's plugged into the mains. It works perfectly when it's plugged in but won't function otherwise, no matter how long I leave it to charge.
Rechargeable batteries don't last forever. When I searched Amazon for "JVC GZ-MG21EK battery", I found lots, from about 9 pounds sterling ($12).
Nov 21, 2010 | JVC Everio GZ-MG21 Camcorder
I lost mi cd rom for camera Jvc everio GZ-MG330 Drivers
Please get the driver at jvc website then.
Regards
Oct 19, 2010 | JVC Everio GZ-MG30 Camcorder
Jvc gz-mg30 no power up from mains or battery no lights or sound dead
the battery of camcorder is not working properly.get the battery replaced or take it to service workshop for detailed check up of inner circuitry.
Dec 04, 2009 | JVC Everio GZ-MG30 Camcorder
Deleted Videos on JVC Everio GZ-MG27U
Sometimes the "my computer" could help. go into it after plugging in your camcorder choose the file and search through the folders.
Aug 24, 2009 | JVC Everio GZ-MG30 Camcorder
I need an instruction manual for a jvc/everio GZ-MG130U.
GZ-MG30UA:
http://books.jvc.com/booklist.asp?Model=GZ-MG130UA
GZ-MG30UB:
http://books.jvc.com/booklist.asp?Model=GZ-MG130UB
GZ-MG30UC:
http://books.jvc.com/booklist.asp?Model=GZ-MG130UC
GZ-MG30US:
http://books.jvc.com/booklist.asp?Model=GZ-MG130US
Apr 30, 2009 | JVC Everio GZ-MG30 Camcorder
Cannot find manual.need to know how to charge camera
You can download it from JVC's site: http://support.jvc.com/consumer/product.jsp?modelId=MODL027544&pathId=12&page=1&archive=true
Don't know this particular model, but most cameras will charge battery only if they are switched off.
Mar 20, 2009 | JVC Everio GZ-MG30 Camcorder
JVC EVERIO gz-mg330 does not appear as drive
Another solution is to make sure you are using the usb cable that came with the camera. For some reason, if I use any other, the computer won't recognize the camera. It's the one with the magnet. In fact, mine has two magnets on it.
Jul 07, 2008 | JVC Everio GZ-MG30 Camcorder
My camera will not turn on. It doesn't matter if the battery is attached or not or if the camera is plugged in. when switch on my camera the red lights on top comes on. but the screen is dead and it will...
i am having a problem with a borrowed everio (gulp) -
it will only power on if attached to the wall charger - otherwise, it wont recognize the battery - although the battery is full and works fine with other everios. an expert said they were made poorly and i just have to take it in to service
Jun 28, 2008 | JVC Everio GZ-MG30 Camcorder
buy a new one i have a brand new jvc gz-mg330 for $320
tflamable@aol.com email me
Jun 23, 2008 | JVC Everio GZ-MG30 Camcorder
JVC Everio GZ-MG30 Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
