Question about Frigidaire 32" Built-In Electric Cooktop - White
Hello Fixya, I possibly might need a
Hello Fixya, I possibly might need a replacement switch for my Frigidaire mdl RBB-101 cooktop. The speed heat burner will not heat up. A local appliance parts did a continuity check on the element and it checks OK. They said if it is the switch, that they can no longer get it. They recommended replacing with just a regular speed switch. I really would like to keep it a speed heat burner. Do you happen to know of any suppliers for the speed heat switch? Thank you for any assistance! Tim
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Posted on Jan 05, 2008
  • 409 Answers
SOURCE: smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Posted on Sep 30, 2008
  • 1462 Answers
SOURCE: Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Posted on Nov 20, 2008
  • 222 Answers
SOURCE: Need to know part nos. of gas burners and blackcaps, PLEC36S9ECA
try to bring the small part wen the place the burner cup(black cap) in the store wat brand u have also use other brand but bring it to put it in actual.
Posted on Dec 02, 2008
SOURCE: I have a Frigidaire Ceramic Glass cooktop.the main
I'm having the same problem! Except I'm not guarenteed any heat even on high.
Posted on Jan 07, 2011
The indicator light for the stovetop remains on despite all the knobs for each element in the off position. One of the elements is still getting power and heating slightly despite all controls in the
Hello friend, thanks for your post!
I see that the indicator for your cooktop continues to remain on for your Frigidaire range. It sounds like it could be a potential issue with your switches or control panel. I would recommend a reset on your range which you can do by flipping the household circuit breaker off for ten minutes. I hope this is helpful. -Matt
Oct 11, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
316065306how many watts to run this range
Hello friend, thank you for your post!
I understand that you are searching for the wattage on your Frigidaire range. In order to provide you more information I would need to have your model number. You can locate your serial tag (which lists your model number) on the outside of your cooktop base possibly on the edge or bottom under the unit. Once I have that information I can further assist you. I look forward to your response. -Matt
Aug 19, 2014 | Frigidaire 30 in. Electric Ceramic-Glass...
FFEC3205LW replace switch
I see you are attempting to replace the switch on your Frigidaire oven. Some of these intricate parts do require precision and patience, therefore when replacing the exchange of such electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Aug 15, 2014 | Frigidaire Stove / Oven / Range Cooktop...
I have a Frigidaire cooktop, model #GLEC3689EBB. We prepared a dish for supper, went into the dining room to eat. Something smelled hot and when we went to the kitchen, another burner was glowing red (not...
Hello Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing it appears that your Frigidaire cooktop may possibly have a faulty switch or EOC (electronic oven control). This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
Jul 07, 2014 | Frigidaire Cooktops
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Smooth surface frigidaire electric cooktop
hi there,
Sep 30, 2008 | Frigidaire 31 in. GLEC30S9E Electric...
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire 32" Built-In Electric Cooktop - White Logo
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
