Question about Acer Aspire 3610 Notebook
New AC Adapter Will Not Charge Battery/Operate Computer
I was using my laptop the other day and while unplugging my AC adapter from my computer it shocked me. After that it wouldn't charge my battery or allow me to stictly use my computer through AC usage.
Given my adapter was pretty jacked up, I purchased a new one of the exact same type and this new adapter will not charge my battery or allow me to use my computer through AC usage either.
I've removed the battery and left the adapter plugged in and it still doesn't work.
Problem is?
  • 1 more comment
  • crazymaesey Nov 12, 2009
    Thank you!
    So how would I go about fixing this? What would I need to replace?
    Thank you!
    Now what would I do to repair this? Any idea what to replace?
    By the way, the computer worked fine after this. It worked for an hour or so on the battery left. Now I just can't charge it or run on AC and the battery is dead.
  • 748 Answers
Most probably static electricity killed some circuitry inside your laptop.
Posted on Nov 12, 2009
  • Stan
    Stan Nov 12, 2009
    Well, fortunately the damage is limited.
    There's no easy fix for this kind of problem. If the unit is in warranty, I would strongly suggest sending it for repair - but I wouldn't be too elaborate on how it happened ;) Just doesn't charge anymore :)
    If it's no longer under warranty, it must be inspected by a serviceperson, and it will cost some money. If the service likes to troubleshoot the old-fashioned way, the replacement part(s) may be rather cheap. If however they do it the modern way, like replacing the whole motherboard because one part is dead - it may cost much more...
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Gateway lt21 netbook not charging
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 13, 2010 | Gateway Computers & Internet
Battery not charging
Hi. I would suggest that you powerdrain your computer might fix this. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. If this doesnt work try to powerdrain again the laptop then just use the ac adapter to turn on your computer and that is without the battery. If this one work consider replacing the battery or you call the tech support dept of HP if you are still under warranty so that they would replace it with a new battery without any charge. Hope this helps.
Jun 03, 2010 | HP G60-120US Laptop
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Laptop will not power up with Adapter
It sounds like there is a problem with your motherboard. You would have to take it someplace to run diagnostics on it. It may be time for a new laptop
Apr 14, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Acer Aspire 3610 Notebook Logo
124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
