Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint hss25gfph ww evaporater fan is not running. something was clicking yesterday. fan spins freely when you turn it by hand. just replaced the condensor fan yesterday. it was locked up. fridge and freezer both got cold, but this morning the evaporater fan is not running.
  • Hotpoint Master
  • 1,606 Answers
You need to replace the main control board . One of the resistors , are burnt , keeping the DC voltage , from reaching the fan . Check to see if the fan will run off a little 9 volt battery . If so , replace the board . Pt # WR55X10656 . The board cannot be repaired ( with this problem ) and has to be replaced .
Posted on Nov 13, 2009
  • 2,237 Answers
If there is no power going to it, check for a break in the wire or a blown fuse or relay on the main board. if you do get power to it and it doesn't spin, replace the fan. there could be a bad winding.
Posted on Nov 12, 2009
I have a frost free hotpoint and theres ice on the freezer door and the food inside it what could this be and how,do i fix it
Hallo
Frost free means there is an evaporater coil behind the backplate of the inside of your fridge.
How it works is a fan is for example installed in the lower back of your fridge and the evaporater above the fan covered by a plastic cover/steel plate and now the fan is pulling the warm air from the top over the evaporater ( the evaporater is then pulling the warm air into the evaporater without increasing the temperature of the evaporater) and dehumidify at the same time and blowing the cold air out a the bottom of the backplate while the warm air moving to the top where it could repeatedly repeat this action.
Tell me what is the condition of your freezers door seal? It can only be caused by humidity getting in so it mean the door is not sealing 100%.
Regards
Jun 09, 2016 | Hotpoint Refrigerators
Air handler blower fan doesn't blow. It does jerk a little every half-second or so.
When it tries to come on give it a spin with something safe (not your hand). If it takes off and runs replace the capacitor. It may just be missing the initial boost it needs to take off from a dead stop. That"s the capacitor's job.
Nov 27, 2013 | Rheem Ruud 51-24272-01 Blower Motor HVAC...
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Location of defrost timer on hotpoint hss25gfph ww
The defrost timer is part of the main control board located on the rear of the unit. Here is the new updated board for that unit.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
Nov 19, 2012 | Refrigerators
No power to freezer fan on hotpoint ffa91
On some of theses units the fans are connected through the defrost bi metal. When the bi metal gets cold the fan comes on. Check and replace bi metal. Should solve your issue.
Aug 18, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
No ice/whole unit not cold enough
Yes, it is possibly some freon was lost but I doubt it. It is very possible a fan froze when it was moved. I would assume when the fan motor got cold the lubrication got stiff and will not let it start again. You should also check the condenser fan first and be sure the coils are clean. If that is all clean and working, check the fans in the refrigerator and freezer. The freon thing would be the last thing to check and you will probably need a person licensed to make that check.
Good Luck,
Gilsh
Nov 26, 2009 | Hotpoint HSS25GFP Side by Side...
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
HotPoint fridge clicks and the fan doesn't turn
14 vac indicates a bad motherboard.Clicking could possibly be a bad start relay on the compressor.
Relays are inexpensive. I would replace the relay and hope for the best. Next step would be the motherboard that GE has had trouble with from day one
Jul 21, 2009 | GE Refrigerators
HSS25GFPA WW HOTPOINT REFRIG.
Please don't rate this solution because people generally don't rate well when it's bad news, even though the response is correct. When the DC evap. motor goes out, it can take out the motherboard. (located behind the small panel on back of the refrig.)
Oct 22, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
346 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
