Question about Heavy Machinery
What is spark plug gap settings for industrial plus briggs and stratton 5 hp engine in a shredder/chipper
  • 366 Answers
Should be .030
Posted on Nov 12, 2009
Briggs stratton spark plug gap
i have a 18hp briggs and stratton opposed twin, it is hard to start and backfires through the carb
Jul 10, 2013 | Heavy Machinery
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Spark plug gap for a rc12yc on 22 hp engine
Gap setting for a Champion RC12YC spark plug is .030
Apr 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Van Guard 16 hp D.C. Chipper with Gravity Flow. With fuel switch on and starting engine four minutes, white smoke apprears and increases gradually, then heavier and chokes itself...
Sounds like your carb is flooding. Inside the carb, there is a simple valve that shuts off the fuel flow when the fuel bowl is full. If this valve fails, or if the float sinks, then too much fuel is forced into the cylinder and will wash past the rings and into the crankcase. This causes the engine to run very rich. You need to remove, clean and overhaul the carb, and change the oil and sparkplug and probably the air filter too. Find the model, type, and code numbers on the engine and go to www.partstree.com , www.ordertree.com , or your local repair shop to get the needed carb overhaul kit. Some B&S engines have an option of carbs, so look for a name on the carb itself...probably Nikki or Walbro. The carb kit is not very difficult to install, but make sure to get everything very clean before reassembly.
Good luck.
Sep 24, 2010 | Briggs & Stratton Chipper Shredder Patriot...
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
5 hp briggs & stratton on a chipper/shreader
if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
Jun 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Have an old wood chipper/shredder don't know the make but the engine mode is 130902. I can not get it started and when I could it was very hard to start. I do not have the manual so I can't tell what the...
Magneto coil adjustment is normally about 1 newspaper thickness for a guide. The spark plugs for these small engines usually are preset in about the right range, & I rarely gap then when I work on the small engines. Also check your carb to make sure its clean while you are at it. Rick
Apr 08, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Heavy Machinery Logo
186 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
