Question about Zenith Pro 900X Multimedia Projector
PRO 900x died
All 3 lamps went dead - a little click and no picture at all ...
    Sergeant:
  • 227 Answers
For all three to go out at the same time with a little click sounds like a thermo switch. Look for button type silver in color and two wires from it. With an ac tester check with power on to see if you get voltage on both sides or at both connections. Naturally one side of your tester has to be grounded to get 110vac reading on either side of the thermo switch. I f power only on one side you have a bad switch.
Posted on Jan 16, 2009
Rca p61960 model has sound but no picture
Control board and lamp may need replacing. Start with the lamp and then have a pro check the board if necessary. Good Luck
Nov 20, 2013 | Televison & Video
I have a Sony Wega 42", my picture went out! Now there is a lamp light flashing? What is this?
Flashing lamp light indicates that tv needs lamp replacement as existing lamp is dead/ broken.
Replace lamp in tv to solve this issue, please buy Sony original lamp for good picture in tv.
Thanks.
Dec 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Toshiba #50HP16. The picture just went out without any warning, could still hear the sound. Turned it off and now it will not come back on, not even the sound. You can hear licking like it is...
U hear alots of clickings,when power turn on?Yes,the tv projection lamp might be dead also,require replacing?But the board call the Ballast board is 100% dead.This Ballast board job,it to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy parts like projection lamps and Ballast boards for DLP projection tvs brands.
Oct 19, 2010 | Toshiba 57H81 57" Rear Projection...
My theaterview tz61v61 has no sound or video i checked the fuses on the on board circuit and, with the ones i could see, seem to be fine i have little knowledge of tv ciruits and tv troubleshooting. ...
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Aug 05, 2010 | Toshiba TZ61V61 61" Rear Projection...
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
Will not boot/start
Yes, that capacitor has died. If one has died it means that others are also very close of dying. Because of that most likely your processor isn't getting the power at the correct levels so it can't work.
Time for a new motherboard, this one is dead.
Jul 01, 2010 | Computers & Internet
The tv isnt turning on at all what is the problem
Targa 32" LCT TV, No picture/ sound only can hear clicking sound from Kisan KP-301R Power supply board. Have checked output voltages and they are a little out i.e. 16v instead of 17.5v and 10.5v instead of 12v.
Has SAMWHA capacitors but cannot see any bulging or leakage anywhere like other users have suffered so dont know if changing all the caps will solve the issue.
Before it finally went dead LCD TV would switch itself off after some time and just a few days before it dies it started the clicking sound but would then start up okay.
Jun 18, 2010 | Sylvania LC225SSX LCD TV
Have to frequently replace lamps on Samsung 50% rear projection
U hear many clicking atemp,before the tv even turn on or trying to turn on.Ur ballast it dying or dead.Replaced the Ballast to solved this.
May 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My screen went blank and the 3 lights on the front of the tv were flashing (lamp/temp). I ordered, received, and replaced lamp as I had done previously with this problem. The tv worked beautifully for...
Hi,do you hear any strange noises? if you heart clicking or like wanting to turn on it could be the ballast that's the board that powers the lamp.Do you hear buzzing,whirling,or high pitch sounds?If you do it could be the color wheel which is a little disc looking that when the light of the lamp goes through it creates the colors on the tv.This are the most common failures on samsungs.
Sep 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Newlamp went out in 20 days. lamp light blinks. is lamp dead now?
Biggest problem with DLP tv's is they get dirty (the usually have two or more fans...one in the back w/filter and one under the lamp). If air-flow is restricted the life of the lamp is in jeopardy. Verify air flow & clean filter(s). Replace lamp with exact P/N..not those that say they "are equivalent"...they are not. Also, be sure the lamp lens is very clean.
Apr 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Zenith Pro 900X Multimedia Projector Logo
123 people viewed this question
Top Zenith Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Zenith Office Equipment and Supply Expert? Answer questions, earn points and help others
