Question about Cell Phones
How to change language as well as transferring numbers from sim to phone, assus p552
  • 4 Answers
Go to settings on phone, select language and click on the language of your choice then Copying over - or recreating - all your contact information from Sim to phone
This ingenious and inexpensive SIM Saver Backup and copy device can save you much time
Posted on Nov 12, 2009
Can I transfer my phone numbers from my old sim cardto my new sim card or to the phone without having to enter them manualy
Leave old sim card in phone . copy contacts to phone . take old sim out . insert new sim card . copy contacts from phone to new sim card.
Mar 10, 2017 | Cell Phones
Tip
Best secret codes sony ericsson
<span><b><span><span>1.</span> S</span>ony Ericsson Secret <a>Menu</a>:<span> <span>-&gt; * &lt;- &lt;- * &lt;- *</span></span> (-&gt; means <a>press</a> joystick, arrow keys or jogdial to the right and &lt;- means left.) You'll see phone model, software info, IMEI, <a>configuration</a> info, sim lock status, REAL time clock, total call time and text labels. You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests) </b></span><br /><br /><span><b>2. IMEI Number:<span> <span>*#06#</span></span> -For checking the International Mobile Equipment Identity.</b></span><br /><span></span><br /><span><b>3. Lockstatus: <span>&lt;- * * &lt;-</span> -SIM lock - Do not lock your phone if you don't know the <a>unlock</a> code. This is another good check before you buy any phone, especially <a>second</a> hand ones. If phone is SIM locked, you may not be able to switch to other GSM operators.</b></span><br /><br /><span></span><span><b>4. Shortcut to last dialed numbers: <span>0# </span></b></span><br /><span></span><br /><span><b>5. Shortcut to sim numbers: <span>On main menu type a number and press # </span></b></span><br /><br /><span><b>6. If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press &lt;0000&gt;. &lt;&gt; stands for right arrow button or joystick.</b></span>
on Jul 27, 2011 | Cell Phones
Tip
Sony Ericsson Secret Codes
SONY ERICCSON SECRET CODES:
On the main screen type
Sony Ericsson Secret Menu: -> * <- <- * <- *
(-> means press joystick, arrow keys or jogdial to the right and <- means left.)
You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels.
IMEI Number: *#06#
Lockstatus: <- * * <-
Shortcut to last dialed numbers: 0#
Shortcut to sim numbers: On main menu type a number and press #
If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press < 0000
on Dec 15, 2009 | Cell Phones
I de phoneo factory reset on my samsung Galaxy S3 and it will not remove my phone number. have transfered that phone number to another phone.
Do you still have that SIM card in the phone. # is bound to that SIM. You should have taken that SIM out and put in the other phone.......unless you changed providers.
Feb 27, 2017 | Samsung Galaxy Cell Phones
Help i have just transferred a sim from one S5 to another and want to transfer the number as well.vodafone tell me mobile settings,then profile then change number.were do i find this
if the phone does not ring when the number is dialed
The mobile number has to be done by Voda phone. The IMEI has to be put into the Voda Phone network against the Phone number.
Dial #06# into the phones dial and the IMEI will show .
Note the IMEI
if you want the phone to have the mobile number in the sim for labeling it.
Apps - Contacts
touch finger on the plus
touch finger on Sim Card
go down to phone number
put in phone number
press on done from key pad
press on save top right of screen
Jan 09, 2017 | Cell Phones
How do i transfer contacts and texts to my sim card
Dear user,
For transfer of phone numbers on SIM card you have to go to phone book menu and enter options , inside these option you may find copy phone numbers to SIM card or vice versa, its always good to keep SIM as default memory if you keep changing phones but at the same time you will have limited space and limited flexibility of data storage per contact
As far as transferring SMS on SIM I dobut if its possible now, one thing could be you set your phone now in such a manner that all messages get saved in the SIM memory, this setting maybe available in messages settings.
May 07, 2011 | Sony Ericsson Walkman® W995 Cell Phone
How to transfer numbers between sim and phone memory
Title: how to transfer numbers between sim and phone memory
If you are want to transfer Sim To Memory then-
· Go to your Contacts of your phone and select which number you want to transfer.
· After selection go to the option menus and here you can get the option as Sim to Memory
If you are want to transfer Memory to Sim then-
· Go to you're My Folder of your phone and select which number you want to transfer.
May 06, 2011 | Nokia 6310i
I need master code for nokia 3310 but i don't have imei number
Nokia 3310 Secret codes *#06# To find IMEI
*#7780# Restores Factory Settings..(Memory, language, counters not included)
*#3110# For checking the software (SW) - called firmware revision information.
*#746025625# [*#sim0clock#] To check if the Sim-Clock can be Stopped (Sim-clock-stop is a kind of standby mode which will save battery time)
*#92702689# [*#war0anty#] Phone asks 'warranty code:'
6232 (OK) Displays the Month and Year of Manufacture
9268 (OK) Displays Serial Number
7332 (OK) Displays the date of the last repairment - if found
7832 (OK) Displays (if found) the date where the phone was purchased
37832 (OK) Set the Purchasing Date MMYY (This date can be set only once!)
87267 (OK) Transfers ALL phone numbers, Logo's, and ringtones from other gsm phones
Posted by bulletproof
May 01, 2011 | Nokia Lands Phones
How do I transfer all contacts to my sim card
You will have to transfer your contacts one at a time. To export a contact's phone number to a Subscriber Identity Module (SIM) card in a BlackBerry smartphone, complete the following steps:
  1. Open the Address Book application from the BlackBerry smartphone Home screen.
  2. Click the contact that you want to transfer to your SIM card.
  3. Highlight the phone number you would like to transfer.
  4. Display the menu on the BlackBerry smartphone.
  5. Click Copy to SIM Phone Book.
  6. Make sure that you are attempting to transfer the correct informaton to your SIM card.
  7. Display the menu on the BlackBerry smartphone, and click Save.
Feb 16, 2010 | RIM BlackBerry Pearl 8100
Sim card]transfer card to new phone
Yes I believe so. Most phones these days store all the numbers in the phone and you must manually transfer them to the sim card. Then by putting the sim card in your new phone you will have your numbers. You can generally then transfer the numbers to your new phone, as it is handy to have them in more places than less. This way you have the freedom to change sim cards but always have access to those numbers for example.
Jun 13, 2008 | AT&T Blackberry Curve 8300 Smartphone
Cell Phones Logo
111 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
