Question about Fellowes Powershred 480 Shredder
Does a 480 fellowes power shredder need to be oiled?
    President:
  • 1,126 Answers
Here is a link to Fellows for your Powershred 480 Users Guide. Look on page 7 under Maintenence.
http://www.fellowes.com/Fellowes/Materials/Documents/480series_2005manual.pdf
Posted on Nov 12, 2009
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: how to oil a fellowes os 8cs shredder
Oil straight down into the feed slot. 3-in-1 oil or Marvel Oil are OK to use.
Posted on Jan 05, 2010
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
HOW DO I MAKE A FELLOWES C-480C SHREDDER PUMP OIL
Hi Wendy, push and hold down the "bulldog" button and then hold down the "forward" button. You should hear the pump pumping oil. May take15 seconds before you hear a hum. If you do not hear anything, the pump may have to be replaced. Clogged oil nozzles or tubes could also cause a problem. This is a common problem and Fellowes re-engineered several components to fix this problem. You can google Fellowes to get a phone # to find an authorized service center. good luck.
Nov 20, 2014 | Fellowes Powershred 480 Shredder
How do I clean the sensors
Before you do anything with this machine unplug the power lead. Switching off is not enough.
Everything you can do is in the manual:
link to Manual Fellows 480
Nov 13, 2013 | Fellowes Powershred 480 Shredder
Oil leaks into bin
Do you have an automatic oiler on machine?
If so, drain the oil, unscrew the reservoir plug and wrap threads with teflon tape.
Dec 12, 2008 | Fellowes Powershred 480 Shredder
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Powershed 480
The 480 is a high end shredder but most of your questions depend on the load it has been under for the 6 years. I would check the cutters for wear before buying.
Jun 11, 2008 | Fellowes Powershred 480 Shredder
Only one-half (righ side) of the shredder works, left side does not shred
Fellowes has a five year warranty on the cutting block of their shredders. (The cutting block is that part of the machine that actually does the shredding of the paper) Take it back to the store where you bought it ans they should either replace the cutting block or exchange the entire machine, but it will take about a week or more, depending on where you are located. At least it shouldn't cost you anything.
Sep 05, 2007 | Fellowes Powershred 480 Shredder
Main board
There is a possibility that Fellowes customer service will be able to obtain this info. 1-800-945-4545
Jan 25, 2007 | Fellowes Powershred 480 Shredder
Fellowes Powershred 480 Shredder Logo
609 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
