Question about Cell Phones
Am trying to block a number of a pest texter and caller please
BAD PHONE CALLS-SELLERS -AND SCANERS
download blocker from play store the ICON is a padlock you can stop "with held numbers" also you can put in the unwanted caller and texter's by entering their numbers ; all you have to do is follow instructions by the way it is a free app. good luck you will soon have peace and quiet.
Dec 23, 2015 | Cell Phones
Tip
How do I Block a Caller on my Android Phone
<p>Here we discuss how an Android phone callers to block. These steps can be useful where you want unwanted calls directly instead of manually reject the call blocking. Follow these simple steps to block a caller making a call to the phone. Please note that the various steps may be other manufacturers like Samsung and Sony Ericsson and HTC. But the base should be almost identical. <br /> <p><br /> <p>Option 1 Steps <br /> <p>1. On the All Apps menu, click Blocked callers<br /> <p><br /> <p><span> </span>2. Click Add caller.<br /> <p><br /> <p><span> </span>3. Select from people (which are your on phone book) or just add the caller (if you remember the number).<br /> <p><br /> <p><span> </span>4. If you like people, click Save to finish.<br /> <p><br /> <p>5. If you add the caller number, click ok to finish.<br /> <p><br /> <p>Option 2 Steps <br /> <p><span> </span>1. All applications menu, click Find People. <br /> <p><br /> <p><span> </span>2. Select the caller wishes to block. <br /> <p><br /> <p><span> </span>3. Calling on the Block, "switching to. <br /> <p><br /> <p><span> </span>4. Click OK to close the. <br /> <p><br /> <p>This "Blocked Caller" function can be disabled, as shown <br /> <p><span> </span>1. All applications menu, click people blocked. <br /> <p><br /> <p><span> </span>2. Select the caller that you want to release. <br /> <p><br /> <p><span> </span>3. About Block caller, change On Off. <br /> <p><br /> <p><span> </span>4. Click OK to close. <br />
on Aug 18, 2011 | Google Android
How to block a caller?
http://tag.wonderhowto.com/block-calls-iphone/
Apr 29, 2015 | Apple iPhone 3G
Block number from texting me
screen the number of your texter, go to contacts, then choose "block this number"
May 29, 2013 | ZTE Cell Phones
Need to block caller on att cell
posible solution. ring your phone company eg 2 Degrees, Vodafone, Telecom there is a bit of a prosses to go through tell them you whould like to bar a number from contacting you depending on the situation they may require you to do a little recording of information eg write down times and dates of message or call and what was said they should then bar this number from ever being able to contact you. or simple solution get a new sim card $5 is a small price to pay to be free lol.
Nov 15, 2011 | Cell Phones
How could i block my Cell Phone Number From Caller ID
  1. Just dial *67 before the phone number on your cell phone. This code is the universal command to deactivate caller ID.
    For example, placing a blocked call would look like*67 555 555 5555 (without the spaces). On the receiving end, caller ID will usually display "private number" because it has been blocked.
    Though you won't hear or see a confirmation of a successful caller ID block, it will work.
Dec 12, 2010 | Sony Cell Phones
Every time I get a text message it alerts me by saying "Message from _____" and then the name of the person. I want to silent this feature but I cannot find the feature to do that.
What kind of vacuum is this anyway???
I will try to help you with your problem even though you have not identified your make and model phone and you are in the wrong category. I will try to help you by telling you what I would do with my phone to change this setting. The procedure for changing your phone is probably different ... but perhaps you will get some insight from my remarks.
This is for calls and messages - My phone is a **** style LG. On the left side there are two buttons. I press the bottom one to get a menu list. Next I press the Right Soft Key called 'settings'. Next I select item number 6 called "call alert" I press OK. My three options are ( ) ring only or ( ) Caller ID and Ring ( ) Name Repeat.
I use (>) caller ID + ring and I hear the number or the name of the caller if in my phone book then the ring I have selected for that caller or texter.
Specific for messages ... I select Settings & Tools then I select Sound Settings then I select Alert Sounds then I select Test Messages and then I make my setting.
I hope this assists you with your settings even though I feel you probably dont have the same phone as I.
Thanks for your interest in FixYa.com
Sep 29, 2010 | Vacuums
LG Xenon Speaking names of callers and texters
its because you need to go to "voice commands", then go to "call alert" & "then press ring only"
Jan 16, 2010 | LG Xenon GR500 Cell Phone
Blocking of caller id
I can help you with that, if you dial *67 and then the phone number, for example ( *67-715-392-0123 ) it should block your phone number from comeing up on caller id...........Hope this helps........
Jun 27, 2009 | Nokia N70 Cellular Phone
How to block unwanted Text messages?
go into call settings then common settings then call reject. I have given my unwanted number a group name and then blocked that group! Hope it works.There is also a service security thing in messaging which lets you set up trusted and untrusted lists. I am trying this also.
May 09, 2008 | LG KU990 Viewty
Cell Phones Logo
193 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
