Question about Sony Ericsson Walkman W810i Cellular Phone
The control button doesn´t go to right and left or down or up,so i cant do anything exept press on it
I have a Digihome 19LCDVD911 TV and the remote will not work in DVD mode, why is that?
do not know here but iam surmising that you have to go into menu and select DVD play then it should work ? maybe
Dec 26, 2011 | Televison & Video
"how can i put a
Press Menu - If you see a Setup tab , press the right arrow button to highlight the Setup tab. - If you dont see a Setup tab, press down arrow button to select Setup, then press OK button. -If your camera doesn't have a Menu button, press the Review button then choose Settings.
Press the down arrow button to choose Date & Time the press OK button.
Press the Right/Left arrow buttons to move between year, month and date.
Press the Up/Down Arrow button to scroll through the year. month and date.Use the same procedure to set the Time.
When finished press OK button.
Hope this helps. Rate if it works. Thanks
May 04, 2011 | Cameras
OSD LOCKOUT Display on my Screen HP L1940 Silver Lcd
Release the menu button (check if anything is leaning on it), and press and hold the menu button again until the message disappears (app. 10 seconds). If this doesn´t work, the button may be stuck, or there´s a problem with the hardware.
Nov 02, 2010 | HP L1940 19" LCD Monitor
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
All the buttons work exept the start button.
To fix this you will have to decide if it is worth either replacing it or opening it and potentially breaking it.
If anything has spilled on it, it could have caused damage to the board inside the controller. If not then you should be able to open it and make sure that the start button is not obstructed in any way and that it is sitting on the pad for it press into. Check the other button for reference.
Mar 27, 2010 | Video Game Consoles & Games
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
The screen of my compaq mini is upside down.
right click on the display away from the icons and select the video control panel, it may be the nvidia or Ati panel. When the control panel comes up, look down the left pane and there will be a heading for orientation. Click on that and you can change the orientation in 90 degree increments. You will have to click on 180 degrees.
Nov 14, 2009 | Acer Aspire One PC Notebook
MY SCREEN IS COMPLETELY WHITE....I NEED TO SAVE MY NUMBERS TO THE SIM CARD BUT I CANT SEE CAN SOMEONE WALK ME THROUGH IT TO TELL ME WHAT BUTTONS TO PUSH. I HAVE A SAMSUNG A 737 SLIDER
Okay, if your phone still operates, and you just cant see anything, then here is what you press:
left soft key (menu, its the highest button on the left of the phone) down one and press middle button (address book) scroll down two or three (to make sure you are not on one of the stupid numbers att puts in the phone) left soft key (options) scroll down 13 spaces and right one space (move to sim) down one space and select (move multiple contacts) press the middle button and the left soft key (move all to sim card) press the left soft key one more time and your done! you should be able to remove the sim card and have all your contacts on there.  if you have a question, just let me know.
Dec 23, 2008 | Samsung SGH-E630 Cellular Phone
Clock
In your Instruction Manual you will find the steps for setting the clock for your unit. Please refer to the MENU section of your manual. Please note, to be able make specific setup changes to your KENWOOD unit you must do them while you are in the “MENU MODE”.
· First, press the SRC button repeatedly until it displays STANDBY.
· Then hold down the Menu button until MENU is displayed.
· Next press up or down on the right control knob, to scroll up or down, until the display reads “Clock Adjust” (CLK ADJ)
· Next press in the control knob, like a button, until the time starts flashing.
· Use the right control knob to adjust the setting; Up/Down adjusts hours, Left/Right adjusts minutes.
· Now press the Menu button to exit.
Mar 02, 2008 | Kenwood KDC-MP5032 CD Player
Sony Ericsson Walkman W810i Cellular Phone Logo
24 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
