Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
The refridgerator is on top and warm, we think the airflow is plugged because the freezer is very cold. How do we get circu- lation? We have emptied the freezer and most of the fridge and have cleaned the bottom of the refrigerator around the vents. We did have a lot of things in the freezer that we worry may have been blocking the big air vent. Can we pour hot water down the refridgerator vents
    Sergeant:
    Champion:
  • 215 Answers
The access cover for this type of refrigerator is in the refrigerator section, you must remove the screws and the cover will slide out, if the fan motor is not turning or you have ice build up , you need to replace the fan motor, because it is not working properly, a new motor will allow the air to circulate and this should correct the cooling problem.
Posted on Nov 12, 2009
My freezer works but the refridgerator doesn't get very cold
If freezer works airflow into reefer box from the freezer box is too low, ironically enough although the thermostat saying 1-10 and OFF, controls the temperature/compressor operation setpoints desired, but the second setting saying COLDER/WARMER, when set to COLDER actually makes the freezer box colder by starving the reefer box!!! if you back of that settting to middle the reefer will get air again, A very common issue , caused by this wording, it says COLDER freeezer if you really look most just peg both and say hey the reefers warm and freezers cold??and both are set max cold, or so it seems!
Nov 01, 2010 | Frigidaire Refrigerators
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is cold but refridgerator is warm. older frost free model
Your defrost circuit is probably broken.
Are you getting lots of frost on the bottom of your freezer?
Is there any airflow in the top portion of the fridge? You can test this by blowing a little cigarette smoke into the refrig section to watch the air pattern.
If you have excessive frosting above and no air below....it may be time for either a new heating element or a defrost controller board.
Some older units allow you to just turn on the defrost circuit and see if the heating element has gone bad. You may want to buy the controller first if it fails the forced power on test. Then, if that doesnt do it...you can buy and replace the heating element.
Good luck and be careful.
Feb 03, 2010 | Maytag Admiral Top-Freezer Refrigerator
Frigididaire only staying cold on bottom
You have a bad fan motor remove the ice maker and the back panel of the freezer and you will see the fan blower. changed and will work like new again :)
Jun 12, 2009 | Refrigerators
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Frig is warming while freezer is staying cold.
No, A compressor will get hot for about three reasons.
Low refridgerant.
Lack of airflow, (maybe due to very dirty coils or bad condensor coil fan on modes with a fan)
Or high amp draw. (which would mean you have a bad compressor)
Its more common to be one of the first two, especially low refridgerant.
Dec 05, 2008 | Refrigerators
Freezer is not freezing and refridgerator is not cold enough
have the freon checked for leaks, also check to make sure the compressor is coming on. If it comes on and is warm, boost freon. If the unit is not coming on properly, check the capasitors and compressor
Jul 24, 2008 | Kenmore 64802 Top Freezer Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
129 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
