Question about Canon Laser Class 310 Fax
How do you change the paper size? - Canon Laser Class 310 Fax
How do I get the printer to print automatically using the bypass tray
you can set the bypass tray the size you want then set paper size setting in the printer driver at your PC.
Hold down the [PAPER SIZE ENTER] key more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
Use the [ORIGINAL SIZE ENTER] key to select the paper size you want to set.
The indicator of the selected paper size lights up.
Press the [START] key and then the [PAPER SIZE ENTER] key.
To change the paper size setting of another tray, repeat steps
after pressing the [START] key
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jul 01, 2011 | Toshiba E-Studio 161 Copier
SHARP AR5320. HOW TO REMOVE SEIZED PAPER.
Follow these steps to change a tray's paper size setting.
1) Hold down the [PAPER SIZE ENTER] key for more than 5 seconds to
steadily.
2) If the machine has two paper trays, use the [TRAY SELECT] key to
setting.
3) Use the [ORIGINAL SIZE ENTER] key to select the paper size.
4) Squeeze the lock lever of the front guide and slide the front guide to
match the width of the paper, and move the left guide to the
appropriate slot as marked on the tray.
5) Press the [START] key and then the [PAPER SIZE ENTER] key.
Jan 29, 2011 | Sharp Office Equipment & Supplies
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
The copier is flashing at the "error" light and the screen reads "change reccomended size, common settings" I don't know how to change it
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
Oct 24, 2010 | Canon imageRUNNER 1023iF Black and White...
How do I change size?
if you want to change paper size for copier you should going to user mode then change casset paper size but if you need to change paper size for printer mode and i guess you mean's that you should go to printer properties then select advance then click printing default then change paper size then click apply then ok
Aug 16, 2010 | Kyocera Mita Kyocera-Mita SCANNER RACK...
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Imagerunner 1023if How do I change paper size on printer
you need to change the paper size on the copier or the paper tray dial.you can also select a paper tray from the printer menu..Alt set the printer properties to a paper tray with legal paper and it should overide the setting
Aug 10, 2009 | Canon imageRUNNER 1023iF Black and White...
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Canon ir 2016 digital copier
Are you living in the USA? The size A4 is the Europe size of paper to our letter size... You can try to take the paper tray out and look inside, for any paper jammed in the back of the paper tray area.
Mar 19, 2009 | Canon Office Equipment & Supplies
Canon Laser Class 310 Fax Logo
19 people viewed this question
old marine
old marine
