Question about Peavey Music
My kids broke my gain pod and my eq on my peavy tko 115 where can i get the replacement parts from and what is the discription numbers.
  • Peavey Master
  • 5,603 Answers
Best to get these from Peavey.
Contact the parts dept by email at:
parts@peavey.com
Be sure to give your model and serial number and the exact name of the front panel controls that are damaged.
Posted on Nov 13, 2009
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Nov 17, 2016 | Mackie Music
My Peavy XR800F just had all its pots replaced and now iam getting very low output.. any ideas please ?
Output transistors or the preceding driver stages may be failing. Check for electrolytic capacitors for bulging tops, they will have to be replaced.
Sep 09, 2016 | Ideas Music
I want to know where to buy a Peavy bass cabinet serial number 3E-01473871
Perhaps you needto ask about a model number rather than a serial number. It's doubtful you will be able to find the one specific cabinet with this serial number. Your only hope would be to contact Peavey directly to see if the owner registered the warranty.
Jul 02, 2015 | Bass Music
My peavy escort 1500 keeps shutting off but will come back on if I turn it off and on is it a fuse?
Can't be fuses, as it comes back on!
Questions:-
i) Does it go off when run continuously with volume controls at zero?
(this checks whether the audio output level is causing a problem).
ii) When the unit does operate, is the sound good on both speakers?
iii) Does the fault occur more when outdoors (wind noise tripping the power protection). If so, reduce the low freq EQ setting.
iii) Do the EQ lights flutter when the fault occurs?
This fault has been reported on the Escort 3000 too, see link
Peavey Escort 3000 sound cutting out - Peavey Forum
suggesting this may need a 'electronic modification' to put it right.
Hope this helps.
Dec 30, 2014 | Music
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
Aug 17, 2012 | Peavey Bandit 112 Guitar Amplifier With...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
Can one(1) Peavy PV 2600 amp provide enough power for two(2) Yorkvilles 15" 300W full range and two(2) Yorkvilles 18" 400W subwoofers?
It should be able to do this. You would need to put each type speaker on a seperate side and then use either an elctronic crossover or an EQ set to pass only lows into the side for the subwoofer to block sending highs to the subs.
Sep 15, 2010 | Peavey Pv 2600 Power Amplifier
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Music Logo
117 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
