Question about Toshiba 32A33 32" TV
Will not power up
I have a toshiba 32A33 that is not coming on. When turned on i can hear the high voltage come up but then it shuts off and the LED starts blinking on and off constantly.
  • BTMAN Jan 25, 2008
    I found the vertical deflection ic shorted i replaced it, then it came on and worked some lines at the top 3 inchs of tube similar to retrace lines i ran it for about an hour cut it off and turned on the next day. The same blinking led and the vertical deflection chip shorted again.
    Genius:
  • 1,139 Answers
Hello BTMAN,
This sounds like a HV shutdown problem. I would check the IHVT (Integrated High Voltage Transformer) and the HOT (Horizontal Output Transistor) for shorts. This is a common problerm
I hope this helps, Thank you, Shuttle83
Posted on Jan 24, 2008
Sir .I have Sony Trinitron TV model kv2197m3.it is not power on. If we gave current only a small ocsilating sound is coming and no LED light .but we cut 110v to LOT TV will on and speakers are on and led...
that high whine sound you hear is the circuit crowbar most likely as its shuts down the high voltage because of a bad voltage detected in the circuit. simple for a tv tech but not worth it to the average peroson to fix
Oct 12, 2014 | Televison & Video
DEAD JUST STANBY LIGHT FLASHING AND HIGH VOLTAGE COMING AND COMING OUT A 1 SEC AFTER.
If the high voltage comes up and goes right down something in that area is either shorted , open or bad---only thing in power supply that could cause this is if the main voltage (130 volts plus to the high voltage area is HIGH---the high voltage will go excessive and shut the set down--xray protection.
Oct 25, 2012 | Toshiba 27A60 27" TV
Sony KV28FX60U wont turn on led flashes 7 times
Hello
  1. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 21, 2012 | Televison & Video
Toshiba 32'' tv no power no sound red led in front on and blinks also hearing hissing from flyback model#cx32f60
for sure your tv has power as indicated by your flyback hissing it also indicates leaking high voltage that might destroyed your vertical or any other parts near your flyback ,the flyback itself should be replaced for its high voltage arcing can ruin so many components
Oct 13, 2009 | Toshiba Televison & Video
Blinking red light on toshiba 32a33
Flashing lights on most TV's indicates a faulty voltage somewhere in the power supply or other voltage sensitive section. Like the "check engine" light on most cars, repair will require a trip to the shop. Get an estimate first. In the new world of disposable electronics the cost of repair may exceed the value of the set.
Aug 28, 2009 | Toshiba 32A33 32" TV
Toshiba 32A33 After a power spike
The main power fuse inside the TV may have blown. The rear cover must be removed to check it. Unplugging the power cord from the wall outlet is the first safety item. Finding all the right screws to remove the cover (without taking out some you shouldn't) is sometimes tricky. When you remove the cover the power cord will still be attached inside, so remove the cover carefully. There is a danger of touching residual high voltage near the picture tube. Carefully look for a fuse near where the power cord attaches to the circuit boards. Often the fuse will be obviously burned open (the small conductor inside the clear glass is melted or the glass is blackened). Replace only with a fuse of the same type and amp rating. Putting a higher amp rating fuse or slower acting fuse can have costly and possibly dangerous consequences. Be sure to plug the power cord in when you do your test with the new fuse. If you haven't done anything close to this before, you may want to refer this job to an expert.
Aug 11, 2009 | Toshiba 32A33 32" TV
Tv problem
high voltage leakage around tube.
remove anode, clean area, Dow Corning 4 or silicone.
Sep 07, 2008 | Toshiba 32A33 32" TV
Samsung HC-P4752W No power
Have you tried unplugging the convergence yokes and then try powering up the set? Its not uncommon for that chassis to shut the set down when the ICs are bad.
Jul 04, 2008 | Samsung HCL4715W 47" Rear Projection...
Toshiba 32A33 32" TV Logo
120 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
