Question about Sony Televison & Video
Sony bravia KDL -26S55xx- mozaics across screen, picture trembles
I have new sony bravia KDL26S55xx. we have problems with the picture - on average twice an hour the picture trembles and it displays mozaics across the screen. I had the aerial checked and was advised that the signal was too strong and had a ''filter'' put on which had no impact on any of the problems. I have since contacted a diff company and was told that the mozaics i get were called pixeling and this occurs only when the signal is weak. Can you pls advise what might be causing these faults and what should I do. thank you
  • Sony Master
  • 10,291 Answers
Weather and antenna aim affect digital pictures. If you're using an inside antenna then your position in the room can affect the picture. Sometimes, late at night, the TV station will go to 1/2 power for maintenance and the picture will pixelate. If you are using an inside antenna that is not amplified, get an amplifier, readily available at Walmart or any store that sells TV antennas. Get the antenna as close to a window as possible and high on the wall. Rotate is slowly to get the best picture. If you have an outdoor antenna check for loose connections and hardware that will allow the antenna to move with the wind. During a storm, you can expect the picture to do what it is doing now.
Posted on May 12, 2017
mistersony
  • 320 Answers
SOURCE: green pixel lines
It sounds like a bad LCD panel but you would have to post a picture of the problem for me to be sure
Posted on Oct 18, 2008
Delta009
  • 13 Answers
SOURCE: I have a new Sony Bravia KDL-26L-5000 with Directv
Make sure you have subscribed to a HDTV service with your television provider.
Also, make sure that all of the devices that are connected to your television are HD devices, connected with a HDMI cable, not a coaxial or RCA jack.
HDTVs aren't magical TVs : everything from the source to the television, including your home theater and PVR, if any, must be HD-compatible in order for the picture on your screen to be in high definition.
On BRAVIA screens, I know that, when you select an input, it will briefly show the definition of the source in the corner of the screen. You must make sure it's 1080p. If it's anything other than 1080p, your picture is not in HD.
I remember that my grandparents had a similar problem. It turns out their BRAVIA television was displaying a low quality picture (480i), even though they had subscribed to a HDTV service, just because their satellite receiver was not configured correctly.
So maybe the solution is simply to make sure that each of your devices is configured to display only the highest resolution available (usually 1080p) in order to enjoy the best picture quality. Do not trust "automatic" quality settings, because they tend to select lower quality settings (such as 720p, which is not True HD), when they might be able to display true high definition pictures (1080p).
Posted on Jun 11, 2009
SOURCE: I have coloured vertical lines covering my Sony
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Posted on Jan 29, 2010
  • 148 Answers
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Posted on Feb 03, 2010
  • 177 Answers
SOURCE: My sony Bravia KDL-37P55xx seems to be recieving
Make sure that the TV is on the right setting, either TV for analog pictures, or DTV for digital. Run a complete auto-setup. This will wipe the tuner memory and re-scan. Hopefully this should sort the problem. If you have tested the aerial cable with another TV in place of that one (not just on a cable from the same aerial in another room) and it works but that one won't, then it will be down to a TV fault. If this helps, please rate me!
Posted on Jul 17, 2010
Sony 40 inch Bravia screen has sound, but picture have weird lines that go across screen
It could be caused by a bad T-Con board or defective LCD panel. The panel is more expensive than the TV, so hope that it is the T-Con board. Below is a parts list for your TV model.
http://www.tristatemodule.com/t-Search.aspx?q=KDL-40S2010
Nov 03, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We have a sony bravia 46" tv. Model number KDL-46W4150. It is 2 years old and has now developed black lines on the right side of the picture.It goes half way across the screen. It is like this when...
That sounds correct, I just have to work on SONY BRAVIA KDL-40BR4 with Horizontal lines problem on ther right side, you you tap around the frame, the lines will come and go, this is only 2 years old TV! Poor quality panel made by SONY/SAMSUNG company jointed venture.
Very sad indeed when you paid for BRAVIA series which are not cheap.
New screen will cost more than new TV.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Feb 15, 2011 | Sony BRAVIA W-Series KDL-46W4150 46 in....
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
How to fix problem with Sony TV.When turn on sony Bravia TV KDL-40V3000. It comes on and then turns off,
I just fixed one with the same problem. The light flashed 13 times.
I had to cut one trace on the hv board to one of the lamp drivers.
There is a slight but barely noticeable darken line across the screen but the tv stays on now and the picture is good. I don't
know if the lamps can be replaced but why bother now.
Jun 29, 2010 | Sony BRAVIA KDL-40V3000 Television
Sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Jan 24, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony kdl-v40xbr1 has horizontal lines
I'm having the same problem. I have noticed on mine that the menu when brought up is clear and I can see it perfectly. The picture on all the inputs is just as described above though. BUT, like I said I can see the menu just fine. This leads me to believe that it's not the panel. Anyone have a solution to this, or at least know what could be causing it?
Jan 22, 2010 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony BRAVIA KDL-46XBR 46 in. HDTV LCD Television. I have a problem when the unit is switched on. The screen has 2/3 lines running across it. The picture stays like it for about 10 mins then goes back to...
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 19, 2010 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Sony Bravia KDL-37M3000, bought June 08. The
Get a digital antena,If u using the signal over the air,rescan.If the signal is cable or other pay tv signal.Ur digital turner,it damage.
Jul 09, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony Bravia TV KDL-V32XBR1 picture
Try different cable, if you still get the problem after replacing cables, then you have a defective sygnal board (input board).
Dec 13, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
171 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
