Question about Cell Phones
How can I add new ringtones to my KLG 8700 Shine phone through the Micro SD flash memory card instead of dowloading? What format do the files need to be in?
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | SanDisk 2GB microSD Memory Card
LG Shine Flip KLG 8700, Broken Camera, Ringtone, Bluetooth
i need help to fix my cell phone "lg 8700 shine from telus".
the ringtone doesn't work, but keypad sound works, and ringtone doesn't. how do i fix it?
e-mail at:
selena_cutie01@hotmail.com
THANK-YOU!
Aug 17, 2009 | Cell Phones
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Lg Shine Flip Ringtones
-Make sure the file is appropriate.. 30 seconds or less, mp3 format
-When you add your music to the memory card, it shows up as a song but not as a ringtone right?
The solution is to create a different folder rather than using the “Music” folder the phoneautomatically creates for you. Transfer your music to this new folder you’ve created. The ringtones should show up as long as it fits the requirements
Hope this helps
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Memory card help
that can not be done for the LG SHINE
Aug 08, 2008 | LG Shine KE970 Cellular Phone
Lg shine - downloading music from my laptop
If you want to put music files from your laptop onto your LG Shine, you can either use a LG USB cable or a Micro SD Card.The Micro SD card will probably need an additional adapter to have it big enough for your Laptop or PC slot. Once the music files are on the Micro SD card, insert the card into your LG Shine and go to My Stuff". Then, select "Audio and ringtones" and select the file on your memory card. Press the "Options" button and select the copy function and paste it into your phone.
Jul 28, 2008 | LG Shine KE970 Cellular Phone
Lg shine - cannot access micro SD card which i have inserted.
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
Dec 26, 2007 | LG Shine KE970 Cellular Phone
LG Shine
The software it comes with doesn't do anything for music. When you hook it up to the USB it should go into mass storage mode. Then you just drag and drop music files over. The only problem I'm having is figuring out which folder to put music in since there are 2 menus for sounds/music on the phone. And when you plug the phone in, it brings up 2 drives. One for the internal phone memory and one for the external memory card.
Dec 14, 2007 | LG Shine KE970 Cellular Phone
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
71 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
