Question about Accessories Alarm Siren
Alarm in a 2004 Ford Escape
How can I turn off the alarm? The vehicle is unlocked and drivable, yet the alarm keeps going. It will stop after about 2-3 minutes, but when you get out of the car, it starts up again. I only have one key FOB, and have tried everything on it (lock, unlock, the aux, and every combination thereof) as well as trying locking and unlocking from the inside. Also, how can I avoid this in the future? Please advise.
  • 37 Answers
Not a complete solution but something to try .Using the key lock and unlock the vehicle from the drivers door .Some models in UK have an arm switch on the lock barrel in the door which sticks.
HTH
Posted on Nov 14, 2009
How do I de-activate a2005 ford escape factory alarm?
Bring the car to dealer,
ask... where is the alarm?
Say...where is the fuse for that alarm?
permit the attendant at hand to take out the fuse.
Mar 10, 2015 | 2005 Ford Escape
2004 escape oem alarm goes off when you start the car.
My problem started after a low battery also. It is a different problem than yours but it might solve your problem. Here is my solution. I believe it's worth a try for the price. All signs point to the Accessory Relay (NOT the Accessory Delay Relay). I replaced the Accessory Relay (Standard Part V13081 RY612). It cost me $15.61 with tax. On the 2004 Ford Escape, it is just to the right of the fuses in the fuse box by the driver's side seat. Three days and all good so far. It is well worth the price to see if this works for you like it worked for me.
May 28, 2014 | 2004 Ford Escape
Ford escape alarm
IF you disconnected the battery then the program may be corrupted , Use a scanner to reset the CPU program and go from there. You do not have to start the car to check for damage . Just have a compression test done
Mar 20, 2014 | 2004 Ford Escape
My ford mondeo lx petrol 98' alarm goes off, sometimes more than once i have to keep going to the parking lot to open and close the door only for the alarm to stop but after some time it goes off again.
Your problem is most likely the central locking / alram switch fitted aroun the door lock inside the door void. Try using the passenger door to lock / unlock. If this stops the alarm triggering then you need to replace the switch behind the lock in the drivers door.
Feb 16, 2011 | Code-Alarm Code Alarm Transponder
My 2008 Ford Escape has power. Lights work, wipers, everything works that has power but when I try to turn the key to start it nothing happens. I mean I don't even hear a clicking noise
Check the relays and fuses in the Power Distribution box under the hood. If all are good check the Alarm circuit ignition kill switch. If you didn't get the Alarm built into the vehicle but had it installed after you bought it remove the fuse from the Alarm power line to disable the kill switch. I did have this problem once and it turned out to be the battery on mine, a 2005 with Alarm built in. Unless you have the Hybrid version you could get in 2008 the vehicles are basically the same.
Dec 31, 2010 | 2008 Ford Escape Hybrid
Turn key on and now no dash lites as usual but a flashing lock and no crank in start position. battery was discnnected for service and reconnected, the alarm horn sounds too.
The vehicle alarm system needs a reset......can be done by most mobile alarm companies or it will have to go to the ford dealer.
Oct 20, 2010 | 2008 Ford Escape
Lost the remote for 2004 Ford Escape, need to disable the alarm
try disconnecting the battery cables from the battery for up to a half hour and then reconnect them. im not sure if this will work for you but i have seen it work on some other vehicles, it couldnt hurt to try... hope this does it for ya
Mar 24, 2009 | 2004 Ford Escape
How can I disarm the anti-theft alarm on my 2004 Ford Escape?
How can I disarm the anti-theft alarm on my 2004 Ford Fiesta
Feb 07, 2009 | Accessories Alarm Siren
Accessories Alarm Siren Logo
1,004 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
