Question about GE Refrigerators
GE/Camco Refrigerator Mod No. LXW18JGVRW1, Ser No. LT385084V ceased to function. We didn't notice it immediately as it is our downstairs fridge and all contents of freezer thawed while some produce in the lower section spoiled. There was power to the lamp so I unplugged the cord while we cleaned it out. Let it sit several hours then plugged it back in with cold settings set to mid point. Fan started, compressor hummed for a while, then stopped. Should I suspect the defrost timer? If so, where is it located so I can reset it?
hemantraj
  • 638 Answers
SOURCE: refrigerator not cold enough
check the ventilations my friend
Posted on Jun 15, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
MNTECH
  • 1543 Answers
SOURCE: I have a GE GSS25WGMD BB Fridge. I have already
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Posted on Jun 09, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
heatman101
  • 43501 Answers
SOURCE: The Refrigerator is 2 years old, and is no longer
Hi Chris,
The problem would seem to be that you developed a small leak in the refrigeration system. This is also assuming that you checked and cleaned the condenser coils which are underneath the fridge. Excessive dirt could also cause this, but from what you are describing I would say the problem is more then that and you have a leak...
The only other thing would be thermostat sensor issues, but then the compressor would be cycling and not running steady...
heatman101
Posted on May 18, 2011
Can you guide me where can I find the right part number for Relay overload starter for my Whirlpool Gold Side-by-side fridge.Mod: GD5YHEXLS01 Ser: SP2325250 MFR DATE:06-03 I am not 100% sure if I rea
Go to sears parts direct web site and put in the model number. Found the page with unit parts our the page that list the compressor. It will have the newest part number
Feb 03, 2013 | Refrigerators
I am looking for self cleaning instructions for a GE oven. MOD. VJ33VWLW-3 SER.ZH273130 VOLTS 120/208 KW 8.6 120/240 11.4 LR 27 TYPE B45 CAMCO INC. Made in...
You should have a selector knob turn it to clean then lock door with lever in the front select hrs on the timer should start up
Sep 18, 2011 | GE Ovens
We have an Surveyor house trailer 3 years old, lightly used. The last time we tried to use the fridge it didn't work. Mod#DM2652 Ser#81708076. Checked the outlet that it is plugged into, it works,...
Since your unit is an AC and Gas unit, you need to find out if it works on gas in order to make a good diagnosis.
But from your description, it sounds like your DC power is not at the unit.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jul 12, 2011 | Dometic RM2652 Refrigerator
My g e frig is not defrosting mod gss22wgmc cc i check out relay heater replace board still ice up
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | GE Refrigerators
Hi There, I require desperate assistance for my fr...
Throw it away and purchase a new one
Apr 14, 2017 | Refrigerators
I have a refrigerator freezer mod ED5GHGXMQ00 Ser SP5150693 and is making a noise when it seem that its going to start something and then it has a loud click. Is there something to worry about I've had it...
Yeah, your refrigerator stopped cooling and you better call for service asap. The block pot is called a compressor, not transformer. And most likely you need a new compressor starter.
Whirlpool refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Howling wind sound from the freezer/ice maker (extremely loud)
check the model # you post cannot find match there is a fan in the refrigerator section that some times make noise
Mar 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
323 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
