Question about Polaroid i733LP Digital Camera
You can push the power button and it does not turn the camera on. We have put new batteries in the camera with no luck. Apparently Polaroid does not work on their own cameras or stand behind their cameras. Any help would be appreciated
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Posted on Feb 21, 2008
john_n4
  • 73 Answers
SOURCE: Cannot locate Playback mode for Polaroid i1035 Didital Camera
It may have something to do with your camera running on auto, internal, or sd option for your memory storage.
When you get to your black screen, try pressing the "w" in your zoom to see if you have taken any pictures. You did find the playback mode...so congradulations.
----just an idea
John
Posted on Jan 03, 2009
DUMPLINS559
SOURCE: i733 Polaroid camera will not turn on
well I HAD THE SAME PROBLEM ALL I GOT WAS A BLACK SCREEN & 3 BEEPS,SO GOT A LETTER OPENER AND STUCK IT IN THE SPACE BETWEEN THE ZOOM LENS A FEW TIME VERY CAREFUL PUSHING DOWN THE POWER BUTTON AT THE SAME TIME AFTER A FEW TIMES THE LENS BECAME UNSTUCK..JUST JIGGLE IT A ROUND A LITTLE BACK AND FORTH WITH A LITTLE FORCE.I HOPE YOUR CAMERA WILL START TO WORK AGAIN LIKE MINE DID.
Posted on Feb 05, 2009
SOURCE: My Polaroid i836 won't do anything. I bought brand new batteries.
I bought one today , and I had the same problem. I tried four brand new pairs of batteries and when I pressed the power button it just wouldn't work. I was going to return it tomorrow, but decided to try it again. I inserted the batteries that it originally came with and it finally worked. I tried the other batteries and it worked also, but not on the first try, in the third or fourth try. Maybe on the first few tries the batteries need to warm up? Anyway, it's working now.
Posted on Mar 19, 2009
  • 1705 Answers
SOURCE: My new i1236 Polaroid digital camera will turn
1) The card could be write protected, check the side of the card see if there's a small notch to slide up or down.
2) The camera could have photo protection option switched on, you have to go through the user manual and the camera menu to switch that off.
3) If you don't get too far with the first options, as its new, take it back to the vendor and ask them to demonstrate it to you and to your satisfaction. If there is a problem with the camera, request a replacement or refund under warranty.
Posted on May 03, 2010
Testimonial: "Thanks for your help, I'll try it."
My i1236 camera will not power on.
Is the battery ok, it has more than 3.5 volts?
Sep 26, 2016 | Polaroid Cameras
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
Yes it sounds like you should return it. If you just bought it I would not take the chance, exchange it for another one and see if you run into the same issue. Then go from there. If you need further assistance let me know.
Thank you,
Lee
May 28, 2009 | Polaroid i830 Digital Camera
Jan 12, 2009 | Polaroid i830 Digital Camera
Dropped camera
My camera fell out of my pocket book and busted the door. I glued it. that worked for about 6 months. I need the door for it and it will be as good as new.
Jul 21, 2008 | Polaroid i832 Digital Camera
The camera is a digital Polaroid i834 . It locked up the power. I have tried new batteries and did not work.It was purchased 11-5-07 for a christmas gift.Cannot turn on and the zoom lens is halfway out.
http://www.polaroid.com/service/userguides/digital/cameras/i834_ug_en.pdf
This link is the user's manual for your camera
There is no response from the
camera while pressing any
buttons.
Remove and re-install the battery
or batteries to reset the camera.
Your valuable data stored in the
camera will not be lost
Polaroid Digital Camera Support
USA / Canada: 1- 877 - 388 - 3779
Hours (EST): Mon-Fri 10am - 7pm, Sat 10am-4pm
That is the best I can do for you. Sorry if this is not enough information.
Good luck.
Mar 27, 2008 | Cameras
Comes on to the polaroid screen but can't take pics or turn off
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Mar 23, 2008 | Polaroid I739M Digital Camera
Polaroid PDC 5080
if you don't use it (press a button, take a pic., take a video, etc.) then it will turn off because say you put it in the case and forgot to turn it off, then it won't stay on and waste the battery.
Jan 30, 2008 | Polaroid PDC 5080 Digital Camera
I733 Polaroid camera will not turn on
Jan 12, 2008 | Polaroid i733LP Digital Camera
Polaroid i733LP Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
