Question about Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher
Making loud noises when washing, nothing is obstructing the top and bottom wash arms and the dishes are clean when the cycle is over.
My dishwasher (Samsung) is making these "grinding like" noises. I do not see any obstructions.......
Posted on May 04, 2010
  • 236 Answers
Is there a chance the dishes are moving when the machine is on? Cound the water jets(spraying the door and sides) be the cause of the noise. Is the sound insulating blanket on the outside of the machine? Try running empty on a shor cycle to help diagnose the problem.
Posted on Nov 12, 2009
Dishwasher not cleaning
Remove the panel at the base of unit below door you should find the tech sheet which will tell you how to place unit into diagnostic, on the spray arms make sure the small holes are clean below the lower spray arm is a screen make sure it is clean not covered or cake with calcium build up if it clogged water cannot pass thru to enter the wash pump you can also remove the screws to take the upper halve apart to inspect the wash pump for any obstruction it is possible you could have a bad motor control or both you didn't mention after the unit fills do you hear the wash pump hum or click
Feb 07, 2014 | KitchenAid 24 in. KUDK02CRBS Stainless...
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes have sandy residue and they don't get clean
Hi and welcome to FixYa, I am Kelly.
Cloudy, spotty / dirty dishes post cycle are almost always the result of drain problems.
1. Start at the sick connection and remove the hose. Clear the connection port of any debris and re-connect the hose.
2. Most dishwashers also have and Air-Gap installed above the counter top. If your dishwasher drain has an Air-Gap; remove the outer vocer by lifting it straight off. NOTE the installed position of the inner cap as it will only reinstall ONE WAY. Unscrew the plastic nut retaining the cap and lift out the cap noting the position. Clean out any debris in the cap area. Use a flashlight to inspect the inlet and outlet hose connections. Re-connect any disconnected hoses as a result of inspection or cleaning.
3. Check the waste drain hose for any folds, or kinks. Straighten the hose if necessary.
4. POWER REMOVED completely from the dishwasher. Remove the lower kick / toe panel and access the pump darin house connection. Remove the waste drain hose and clear any obstructions from the port. Re-install the hose.
Test Dishwasher with a glasware wash. Check for post cycle cloudy or spotted glassware.
If the problem persists:
1. Inspect upper and lower wash arm sprayer holes for obstructions. Clear obstructions. Large obstructions will require spray arm removal.
2. Inspect the tub sump area for any signs of debris. If you note debris you may have to also remove the lower wash arm support to clear the debirs. Just note that some wash arms are a real puzzle to re-install to make sure your paying attention to how it came off.
Test Dishwasher again.
If none of the above remedy the problem. The sump housing and pump impeller will need to be inspected for damage.
I would recommend you add 1 cup of vinegar and the juice from a freshly squeezed lemon with a NO DISHES / NO SOAP short wash cycle to clean up the tub area. Then do a NO DISHES short wash with 1/4 cup bleach and powdered dishwashing soap to complete the cleaning cycle. You can add 2 tsp of lemon juice in the final wash to knock down the bleach smell. You don't have to use the lemon at all but it makes a world of difference.
The above information should remedy your current problem.
Thanks for choosing FixYa,
Kelly
Jul 19, 2011 | Dishwashers
Not washing dishes
Hi and welcome to FixYa. I am Kelly.
Dirty dishes post cycle are a sign of draining problems however this is a list of what it could be.
1. A partially clogged drain
2. The timer motor is not functioning properly
3. A broken or worn pump impeller
Here is what you need to do:
Check your entire drain system. Start at the final outlet and work your way backward to the motor pump connection on the dishwasher.
Suspected areas are.
a. The sink connection outlet is clogged (this can be inside a garbage disposal.
b. The air-gap is clogged in the very top part of the air-gap (Usually located on the back of the sink and is around 3 inches tall) Remove the cover, unscrew the top nut and check under the horse shoe bend inside the plastic top for obstructions. Clean as needed)
c. There is debris on top of the the motor pump housing blocking the inlet drain. (This would be inside the housing of the lower wash arm on the very bottom)
d. The motor pump outlet drain port is partially blocked. (only accessable from the motor pump exit hole after drain hose removal.)
A partially blocked inlet tub drain to the motor pump would also explain why the lower part of the dishes are not getting clean. Additionally you would have spotted dishes post cycle.
When the drain is partially blocked some models use the float level switch in the tub to control the advancement of the timer. If the water does not drain the motor pump continues to run and run and the cycle does not advance until the tub is drained and the float switch senses same. i.e extended cycle
One more thing to check is the lower wash arm holes for debris or obstructions.
Thanks for using FixYa.
Kelly
Apr 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
Water at the bottom
check the sump screens inside the tank make sure their clear,also check the wash arm holes for obstructions,check the seams of the arms for cracks
Dec 30, 2007 | Kenmore 15129 Built-in Dishwasher
Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher Logo
1,335 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
