Question about Select Products Health & Beauty
Hearing aid tubes for a Electone Tango 3p hearing aid. Where can i get them?
    Problem Solver:
  • 11 Answers
Rimcnaney,
Where did you get your instrument? This is where I would go to obtain the hearing aid tubes you are requesting. Generally, unless you have the expertise to replace the tube you may be making another problem to solve by replacing this hearing aid tube for an Electone Tango 3p hearing aid.
Consider this;
Experience is a hard teacher, because she gives the test first, the lesson afterwords."
-- Vernon Saunders' Law
Thanks for contacting FixYa.com
Posted on Nov 28, 2009
My right hearing aid is 4 momths old and it stopped working
The Bolero model requires clear passage of sound through the tube that connects it to the dome/tip that fits into your ear. To determine if the tube is blocked, with a good battery inserted and the battery door closed, unscrew the top of the tube where it connects to the hearing aid. If you cup the hearing aid in your hand, it should whistle/feedback. If not, there is something wrong with the hearing aid. If it does whistle, your audiologist should have provided you with a thin, flexible plastic piece (often green) and instructed you how to unscrew the tube at the top of the hearing aid to run the plastic piece through the tube, all the way out the other end of the dome/tip. If that piece can travel the entire tube easily, then sound should be able to. In any case, a Phonak hearing aid has at least a one year manufacturer warranty (a Q90 likely has a three year) and they will pay for shipping both ways to fix it. You need to send it via an audiologist, though.
Jun 08, 2014 | Phonak Bolero Q90 BTE behind the ear...
Siemens lotus hearing aid emits constant tone
Is the (acoustic) tube obstructed or partially blocked ? If the problem is inside the hard plastic flesh-coloured opaque part, you will need to take it a technician, return it to the manufacturer, or replace it. There are no user-serviceable parts inside.
Jan 14, 2014 | Select Products Hearing...
Distorted loud static sound consistantly on phonak unit one year old
Ensure the acoustic tubes are not obstructed. Detach them from the hard plastic flesh coloured part and clean them in warm soapy water, rinse and dry/allow to dry. Reassemble.
There is a possibility that this might be caused by the gain of internal amplifier being set too high, though this usually results in a constant or intermittent high pitched whine. Try adjusting the recessed wheel on the unit.
If neither of these measures cures the fault, you will need to take it to a technician, return to the supplier/manufacturer, or/and replace the unit
Aug 12, 2013 | Select Products Hearing...
How to set volume on Siemens Lotus 23 P
You may be able to adjust the sensitivity of the device iusing the small, partially recessed wheel on the back of the unit - in fact this is the largest of the controls !
Otherwise you need to take the unt and yourself to an audio technician for adjustment
Apr 16, 2013 | Select Products Hearing...
I find that my BTE open fit hearing aid solves a lot of problems but the fitting seems to creep away from the ear drum making it difficult to hear. I find I am continually pusshing the tube back to where...
There are a couple of solutions that you can try, ask your audi to fit a sport lock or change the tip he is using. If that does not work, think about investing in a set of custom made tips. A sport lock is a piece of plastic that attaches to the tubing, when you place the tip in your ear this piece of plastic is folded around the inside of your outer ear along the bowl.It aids retention of the tip.
Mar 11, 2011 | RTO 2 Siemens Pure 700 Open Fit Hearing...
Squealing at random when volume is at approx 50%
Take your hearing aid to your specialist. Check on wax in your ears. Also are you near a window when the feedback occurs? Due to the phase-cancellation in hearing aids sometimes the signal bounces back and thinks it's feedback.So the hearing aid sends out it's own frequency at 180 degrees and hits it to cancel it out. If this is a false reading however the hearing aid will create its own feedback
Rick
Apr 04, 2010 | Select Products Hearing...
Can you let me know siemans hearing aids one colour coded red and one black which earsa do they relate to
Red it right. The black you see is probably a dark blue and blue is left in audiological circles
Dec 21, 2009 | Select Products Hearing...
The pipe in my mould is too thick, would that cause slightly muffled hearing?
Only the recommended OEM parts are always the best. but if this is happening in an emergency or you are far from base, then try it. If there's no change in sound, then no cause for worry.
Oct 05, 2009 | RTO Hearing Aid Bte Ear Mold Tubing 12...
Health & Beauty Logo
459 people viewed this question
Top Select Products Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Select Products Health and Beauty Expert? Answer questions, earn points and help others
