Question about NEC G100E Cellular Phone
Tmobil g1 phone ringer not working - NEC G100E Cellular Phone
My sound went out on the phone, no music, can't hear incoming ring or alarm??? please help...
is your phone hanging too?? then it might be a software problem.. if not hanging your phones speaker would have got repaired.. so give it for service...
Jul 09, 2010 | HTC G1 Smartphone
My G1 won't make any ringing or media sounds
go in setting ringers and display and check your volume
Oct 11, 2009 | HTC G1
Doesn't show option in choosing personal music as a ringer
If it's running WM then if you touch and hold on the file the option box which comes up should have a Set as ringtone option. Otherwise you need to copy the files into "my device\windows\rings" folder
Oct 10, 2009 | HTC G1 Smartphone
Phone ringer not working
try resetting the phone. If thet does not work take it to the company for service
Jul 27, 2009 | HTC G1
How come my g1 phone sound does not work, the audio does not work at all, it only vibrates
this happened to my friends blackberry, make sure the sound is turned on, or in a profile that is set to play sounds, and see if it works. if it doesn't pull the battery out for a few seconds then put it back in, thats what fixed hers
Jul 14, 2009 | HTC G1
All sounds stopped working, including the ringer, speakerphone, and notification alert. How can i fix this?
is your phone the HTC - G1?
Please let me know which phone is it, it could be a hardware issue with the speaker, but let me know what phone it is so I'll get you some solutions to try.
Jul 08, 2009 | HTC G1
Ringer and speakerphone not working
a lot of the system volumes were put back to default. I only realized this when I downloaded the "Audio Manager Widget". Then I found that I apparently missed a couple volume settings.
also It might be due to the In-Call volume. The only time you can adjust the In-Call volume is when you're in a call (duh!). So, I called my voicemail and put it on speakerphone just left it all the way up and now I can hear the dialpad tones again!
also I think it was swapping from vibrate to full volume when I received an SMS (or was doing multiple things at once).
All sound stopped working on the device. It's an Dream from Optus.
try a quick reboot.. that shud fix all the problems though
if all the above moethod fails... its time to call the manufacturer....
good luck
Speaker not working
More then likey you will have to perform a master reset to the device
Feb 02, 2009 | HTC G1
NEC G100E Cellular Phone Logo
37 people viewed this question
Top NEC Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a NEC Cell Phone Expert? Answer questions, earn points and help others
