Question about LG Studioworks 563N 15" CRT Monitor
No display on computer or TV but plane raster and cable not connected message is displaying when disconect from computer or TV
All three color pin(red,green & blue) is disconnected from data cable
Posted on Feb 13, 2010
  • 45 Answers
Check whether your RAM is ok or not...
because the display problem may arise from the RAM..
Samsung led TV 28' bad display after two second raster plane & various color show on display
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 31, 2016 | Samsung Televison & Video
Blue screen has audio can change channels and hear different audio but no picture
Hello
If you can see menu on-screen display, just get into it, surf for blue-back option and turn it OFF first, and see whether there is any grains appears on your screen. If there is no grains, and only a plane raster, your TVs video processor Ic has got damaged, and should need replacement. If there is grains, you just retune it in autotuning option, and allow it to store all the transmitting signals at that time. This process may take two or three minutes to complete, and you should wait till then. Never forget to connect antenna socket to the antenna terminal of your tv.
If you are using set top box, and connected it to the TV through audio-video cable, your TV has no fault, but the set top boxs' video processor has got damaged. OK,
Nov 24, 2010 | Sanyo DS31520 31" TV
I'm connecting to a tv with a VGA cable from my Acer netbook. My tv says No Signal. Windows makes the "ba dum" sound when I connect/disconect the cable, but under my display settings, it doesn't...
Don't forget that the TV source or input needs to be set to "PC". Once that is done turn the netbook OFF, then plug the VGA cable into the netbook and start the computer. The computer screen should automatically show up on the TV.
Nov 10, 2010 | Acer Aspire One PC Notebook
Display problem
sir,mam you need to check first your cable connection for proper ground,maybe insuficient grounding on your cable and that why your reception signal become snowy.
Aug 29, 2009 | Philips 107E61 17" CRT Monitor
Canon S450 wouldn't print test page
hi
i first need to know what is the eror message
you need to uninstall\reinstall the printer
this can solve your problem
Uninstall and Reinstall the Printer Driver (Windows) Instructions to uninstall the printer driver
  1. Select 'Programs' or 'All Programs' from the 'Start' menu.
  2. Select the printer driver you want to uninstall, and then select 'Uninstall'.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the uninstallation is displayed. Wait until the "Uninstall successfully completed" message is displayed.
  5. When the message is displayed, click 'OK'.
  6. This completes printer driver uninstallation.
Note: If you use Add or Remove Program to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in Step 2.
Instructions to install the printer driver for the using the prepackaged CD (Windows) Before installing the printer driver, confirm that the printer is powered off.
  1. Set the prepackaged CD into the computer. (The installer starts automatically, and the following window is displayed.)
  2. Select 'Printer Driver' on the left side in the window, and click 'Install'. (The Printer Port dialog box is displayed.)
    Note: Click 'Readme' to refer to notices on installation.
    Initially, the manual is installed.
  3. Confirm that printer and computer are connected, and turn the printer on.
    Note: To display the explanation about the printer port, click 'Help'.
  4. The Printer port window will be displayed while automatic recognition is performed. (After automatic recognition is completed, the window will close automatically.)
    Note: It may take a while to recognize the printer automatically. If the automatic recognition is not completed, re-connect the printer cable again. If you want to select the port, check Select printer port, and click 'Manual' selection.
    When the printer driver installation is completed, the message below is displayed. (Installation of the manual and printer driver, and the system setting change are completed.)
  5. Click 'OK'.
    Note: If a BJ Raster Printer was previously installed, the following message may appear.
  6. Click 'Yes' to restart the system.
    Note: In the Windows 98/Me environment, if a BJ Raster Printer was previously installed, it may be necessary to re-start the computer in order for the USB port driver to be updated. In this case, click 'OK' to re-start the system and begin the installation process again.
if you are not able to do so write me a email
Jun 19, 2008 | Canon Office Equipment & Supplies
Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Jun 08, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Display problem
I would be checking the ballast supply and the back plane lamps to start with.
Jerry G.
May 04, 2008 | Panasonic TC-32LX60 32 in. LCD Television
NO PICTURE
do you see anything on screen.no picture doesnt mean no raster ,raster mean anything that comes out in display.no raster with sound only mean failure in either,connection in heater which means, loose connection or some new sets declare failure in vertical circuit.so be more specific ok?
May 08, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
LG Studioworks 563N 15" CRT Monitor Logo
80 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
