Question about Sony Ericsson w580i Cellular Phone
No display visible but when i plug in to charge the handset vibrates as if it's active.
I have a Siemens Gigaset A420 A Trio obviously three handsets.
Chargeable and non-rechargeable batteries are not interchangeable.
Aug 02, 2016 | Siemens Gigaset A420a Trio Dect Cordless...
Uniden 6.0 dect phone interchangeable with different 6.0 uniden
when the battery cover comes off there are a series of microswitches that are visible.. make sure the new ones are set with your originals..
Jan 11, 2014 | Uniden DECT 6.0 Cordless Telephone...
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
Jun 25, 2011 | AT&T E5640 Phone
Can u please tell where to find blue tooth on nokia c3110
To use the Bluetooth function on your handset, you will need to select Menu>Settings>Connectivity>Bluetooth. Then you will need to activate the feature. To do this, select ON to activate it. Then you will need to make your handset visible, to do this you will select visibility, or my phone's visibility, to the ON position. This will enable other Bluetooth users to connect with your handset for sharing. Note: You will have to accept when someone is trying to connect to your handset via Bluetooth if you wish to accept. To pair with a device, you will simply select search for device, and it will pick up any Bluetooth devices in the area. Please note that your device is Bluetooth A2DP capable, which means that you can use any Bluetooth technology equipnent that is A2DP and below, it is backward compatible. You will not be able to pair if the Bluetooth technology is greater than A2DP. You also have the ability to name your handset, to do this simply select My phone's name, and choose the name that you desire the handset to have. This will make it easier for someone to pair with you if you choose to share files.
Mar 20, 2011 | Nokia 3110 Cellular Phone
Phone displays a message saying no link to base when it is closer to the base?
Following may be the cause for getting no link to the base.
1. The handset has lost communication with the base unit.Move closer to the base unit, and try again.
2. Confirm that the base unit’s AC adaptor is plugged in.
3. Raise the base unit antenna.
4The handset’s registration may have been cancelled .Re-register the handset.
To Register, follow the below steps.
Headset: Press MENU and then press ‘0’ ‘0’
Base unit: Press and hold HANDSET LOCATOR until the CHARGE indicator flashes.
(After the CHARGE indicator starts flashing, the rest of the procedure
must be completed within 1 minute.)
Handset: Press OK, and then wait until the handset beeps.
Your handset is registered to Base unit.
Thank You
Aug 18, 2010 | Panasonic KX-TG2620 Cordless Phone
My panasonic kx-tga520m cordless handset does not display caller id anymore. the second handset does display this feature. What should I do?
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Jan 18, 2010 | Panasonic KX-TGA520M Cordless Expansion...
Hand set out of range disply is on. How do I reset.
here are some tips from my manual for out of range problems
hope they help
• Only one handset can be used to make or answer a call anytime.
If another handset attempt to do so, the screen will display OTHER
HANDSET ON and then OR OUT OF RANGE. You might press PHONE
or SPEAKER again until no other handset is using the line. Use the call
transfer feature to transfer a call to another system handset
or use the speakerphone feature so multiple members of your
house can be on an active call at the same time.
• Move the cordless handset closer to the base. You might have moved
out of range.
• Ensure that the base is powered up.
• Place the cordless handset in base cradle for 1 minute to allow the
cordless handset and base to resynchronize channels.
• If the cordless handset is in its base and the charging light does not
come on, refer to the charge light is off in troubleshooting guide.
• Reset the base. Unplug the unit’s electrical power. Wait for 15 seconds
then plug it back in. Allow up to one minute for the cordless handset
and base to reset.
• Other electronic products can cause interference with your cordless
phone. Try installing your phone as far away from these types of elec
tronic devices as possible: wireless routers, radios, radio towers, page
towers, cell phones, intercoms, room monitors, televisions, personal
computers, kitchen appliances and cordless phones.
Jul 16, 2009 | GE 29897GE1 Corded Phone
Display has been broken down..
looks like you need to replace ur display go to any mobile repair shop and he will do it for less
Oct 17, 2008 | HTC Touch P3450 Smartphone
Expandable handsets lose activation:
USer manual requires,
full charge 16 hours for expandable handsets, then place in cradle ~20 seconds until 'ready' is displayed on the screen.
If power is lost the handset may have to be re-registered.
if the units are not fully charged when you register them the registration may be lost, can only suggest reversing the order, by fully charging the device then registering to see if the registration holds
Nov 12, 2006 | GE 25931EE1 Phone
Sony Ericsson w580i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
