Question about Apple iMac G3, G4 USB Keyboard 9224078
Blueberry iMac with slot-loading CD rom drive will
G3 Blueberry iMac with slot-loading CD rom drive will not eject the CD. The drive whirs and tries to eject but the CD will not come out. Holding the mouse button down does not work, no hole for a paperclip, normal eject will not work. Do I need to complete take apart the iMac in order to remove the CD? Thanks for any help.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Posted on Nov 13, 2009
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
Can't reboot iMac and disc is stuck in the slot loading drive
Shut down the mac by holding in the power button for about 10 seconds.
Is the CD a system CD or something else?
If it's a system CD restart the mac and hold down the letter C on the keyboard. after about 30 seconds the mac should boot up into installation mode. If it does, click on the language then then at the next page go up to the menu bar and locate Utilities and disk utility. Run the disk repair then try and restart. (The flashing ? means that the computer cannot find a start-up drive with a valid system on it. The repair routine can sometimes fix that - it doesn't always though.)
If it's not a system CD and you obviously need to get it out before you can do anything else - restart the mac but this time instead of holding down the C key, hold down the click on the mouse. It takes 10 to 15 seconds (sometimes longer) but it will force the computer to eject t the CD.
Feb 14, 2010 | Apple iMac Z0CY Desktop
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
How i eject a stuck cd from a imac
The front of the CD Driver you can see a very small hole…use a safety pin and open it then insert the pin in that hole and push it in that will force the door on the CD to open …Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Apple iMac G5 Desktop
IMac disk drive ejects audio cds
1) Restart the computer and try again. If that fails, 2) Gently blow canned air into your CD drive slot. If that fails, 3) Bring the unit in for a drive replacement.
Aug 25, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
IMAC G5 DVD-ROM slot keeps ejecting disks
Try cleaning the lens or the drive with a cleaning disk
Jan 03, 2009 | Apple iMac G5 MA064LL/A Desktop
New (to me) blueberry cd stuck in drive
If this is a slot loading machine there may be a little hole next to the CD-Rom drive. Slide a paper clip into the hole and the CD should pop right out. If this is not a slot loading machine then it will be the same procedure only the hole for the CD-Rom will be on the CD-Rom tray itself
Aug 07, 2008 | Apple iMac Blueberry Mac Desktop
Cd rom drive
The drive may be in failure. I would try another drive to verify. I have had this before.
Jerry G.
Jul 17, 2008 | Apple iBook G3 Mac Notebook
Updating a slot loading iMac from OS8.6
Unfortunately, The disks may be DVD, not CD. You might be able to do the install by networking the iMac to the Macbook and using the laptop's drive to read the disk.
Feb 19, 2008 | Apple iMac G3, G4 USB Keyboard 9224078
Computers & Internet Logo
376 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
