Question about Canon BubbleJet i560 InkJet Printer
It prints in color but not black and white. I have uninstalled and reinstalled it. I have cleaned it. It has not been used that much.
  • akannekimbal Nov 17, 2009
    I had replaced the ink.
    Your sentence doesn't make any sense to me. But I solved the problem by doing two - two - deep cleanings.
    Problem Solver:
  • 19 Answers
The ink in it is dry replace it with a new one
Posted on Nov 12, 2009
  • amal_2020us Nov 17, 2009
    then there is a problem with where u put the bottle of ink at where it holds it clean it with the printer solution
Color mismatch and blurry/smudgy prints
Remove ink catridges and clean print head, shake inks and reinstall the inks, if problem persist, Uninstall the driver and reinstall. thats should help. Some time if the print head are dirty it prints multi color. You have to make sure the Head is Clean and install th inks properly.
Dec 10, 2012 | Epson Stylus Photo R1900 InkJet Printer
Color printing
You risk you ruined the cartridge with alcool.
Jul 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
All colors print only black does not print. New
reset your print option set automatic or color select
Aug 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon Pixma mp780 printer will not print colors
I just bit the bullet and went out and bought Canon ink and replaced all my other Print Pal ink cartriges and my printer works like a charm again.
May 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Epson 880 not printing in color
Was gone for the weekend.
Yes, the grayscale option gives you black and white or black tank printing only.
If you go to start menu, control panel, printers, right click your printer there is the option to print test page. In the upper left should be the windows logo in color. If you don't have that and you know you've removed the protective tape for the bottom of the color cartridges and when doing the nozzle checks "you have color?", then you probably need to reinstall your printer driver.
Is your printer connected via a USB cable, a thin cable with a flat connector at the PC and a square connector at the printer. Then, let me know. Send me your printer model from the back of the printer model sticker and I'll send you the instructions and a link to the current driver as well as a program link to download a system registry clean up utility that's free to use and can clean up from an uninstall of your printer.
Regards,
Worldvet
Aug 09, 2008 | Epson Stylus 880 InkJet Color Printer
Prints only Black and White (Monochrome)
Check your Printer properties if it is set to color, chances are printer is setup to print in black and white mode or grayscale.
May 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
70 people viewed this question
old marine
old marine
