Question about Tecnik TKL9260 Front Load Washer
Water is collecting in the drum in between washes . Do we need a new inlet valv? Also, is there a different inlet valv for hot and cold?
    Genius:
  • Tecnik Master
  • 1,466 Answers
1 for hot 1 cold//Water in the drum is it pumping out ok?...could also be drain hose too low taking purgeback from sink drain. raise this to cure...
Posted on Nov 12, 2009
Why is clean water collecting in the drum of my washing machine afer a cycle?
Replace the inlet solenoids. They are where the hoses attach to at top back of machine. Dead easy replacement. Couple of screws and a tubing clamp
Nov 01, 2014 | Bosch Washing Machines
Samsung washer will not fill with water
Remove the power for sometime, check the inlet and drain hose connections. If there is good pressure on the inlet then the flow seems ok to the drum. If so the water level sensor must be checked to allow water to collect and cut off the inlet before allowing the drain to activate. If so the controller is a suspect as it opens the drain valve.
Mar 20, 2013 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Washing won't spin and i have a washing machine full of water , could you tell me how to check the filter ?
First of all you mustt drain the water that is trapped within the drum. So remove the drain pump/ valve and allow the water to flow out - make sure that you have an arrangement to collect water when the drain Hose is removed.
Now the drain pump/valve must be checked clean if there is dirt clogging. Also test the valve for proper functioning. Also check the inlet valve and filter which is on line with the water inlet which can be traced easily. Check the motor, drive , door switch and finally the control board. If after switching on there is no action , inlet filling or spining when water is full, the program controller must be faulty.
May 19, 2011 | Washing Machines
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water continues to flow into the wash drum after the wash cycle is completed
Hello Friend, Your solution is simple. You need to replace the water inlet valve. The cold water inlet on your valve is blocked with hard water deposits or dirt and debri from water lines, causing it to not close completely. This condition is allowing water to enter through the valve when it's supposed to be closed. Replacement is easy. Just replace water inlet valve and your problem will be solved. Happy to help, Tim.
Jun 22, 2009 | Washing Machines
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Tecnik TKL9260 Front Load Washer Logo
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
