Question about Zebra TLP 2824 Printer
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while then a constant red light comes on the feed button.
    Scholar:
  • 62 Answers
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Posted on Nov 20, 2009
THE PRINTING IS NOT LINED UP ON THE LABELS THE FIRST ONE DOES AND THEN IT SEEMS TO LOOSE ITS ALIGNMENT
Label not aligning is usually due to the printer not being calibrated to the label length, Turn off the printer.
Hold the button down on the top front of the printer, Hold
Turn on the printer still holding down the button and wait for the printer light to flash, then let go of the front button.
The printer will now feed out several labels and calibrate.
Turn off the printer, then back on, now try feeding the labels, it should now line up perfectly.
Contact www.lancerlabels.co.uk if you have difficulty doing this
Home
Sep 30, 2014 | Zebra TLP 2824 Thermal Label Printer
Zebra TLP 2844-z printer and when I turn it on the light is blinking green/red
hold feed button and release during 4 blinkings to reset. good luck
Aug 29, 2013 | Zebra LP 2824 Printer
How to install zebra tlp 2824-z
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7
finish the instalation, reset the computer. Turn on again, check on printers and fax, if the icon is there, right-click and go to properties, print test label.
Oct 31, 2010 | Zebra TLP 2824-Z Printer
Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
Nov 16, 2009 | Zebra TLP 2824 Printer
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2824 Printer problem
How are you loading the labels in the printer?
Make sure they are secured underneath the black side guides?
Sep 17, 2008 | Zebra TLP 2824 Printer
LP 2824
Here's the right way to fix the problem.
Autosense Procedure, Configuration Label and Dump Mode:
Models: Orion (2442, 2443 and 2543), Transport (P-2242), Xport (P-2222), LP/TLP Strata (2684), LP/TLP-2722, 2742, 3742, LP/TLP-2824 ,LP/TLP 2844 and TLP-3842
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the "Out of Dump" message on it.
Printer is now ready for use.
Oct 10, 2007 | Zebra Eltron LP 2824 Thermal Printer
Printer will not print
zebra have only just started to support vista, you need to download the latest version of zebra designer from zebra(free). drivers are included
Aug 13, 2007 | Zebra TLP 2824 Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra TLP 2824 Printer Logo
1,210 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
